Torque Managment with Predator
Old Oct 31, 2003 | 06:24 AM
V8_Club's Avatar
V8_Club
Default Torque Managment with Predator
Hi Everyone,
I 'm a new member & would like to benefit from your experience. I was reading regarding the above topic in the forum & this is what I concluded :
Torque Managment needs to go when you have the TRANSGO Installed.
I have the shift kit on order as well as the Predator. Here is my question :
How does the Predator remove the Torque Management ? Is it when I upload the tune program ( because i might not ) or is it when I change the shift points (to 6000 rpm ) & line pressure ( +5% with transgo - any suggestions ?) ( These two i will definately do ) .
P.S. Does Changing the Shift Adaptation Paramater in the Predator do it ? i.e. if i Change it to a negative setting ? ( Any recommendation here ?)
Thanks :steering:
[Modified by V8_Club, 11:43 AM 10/31/2003]
Old Oct 31, 2003 | 10:04 AM
Mike Mercury's Avatar
Mike Mercury
Default Re: Torque Managment with Predator (V8_Club)
it's my understanding that loading the supplied performance tune program will disable torque management.
Old Oct 31, 2003 | 10:08 AM
vstella's Avatar
vstella
I would get someone with a LS1 Edit to be sure..I really don't know if the Diablo Predator will do it for you... :rolleyes:
Old Oct 31, 2003 | 12:32 PM
V8_Club's Avatar
V8_Club
Default Re: Torque Managment with Predator (vstella)
Thanks for your replies. I checked as well , it seems the supplied tune will disable the same once uploaded. :reddevil
vstella,
I live in the Middle East so i doubt ill find anyone here with LS1 Edit. That brings me to another topic i posted, How much does LS1 Edit cost ? Where can i buy it from ? This seems like the better alternative . I can buy the same then can make the necessary changes myself. ( With your help of course guys. Pls :cheers:
To Torque Managment with Predator
