LS6 Injectors
Old Oct 31, 2003 | 08:12 AM
V8_Club's Avatar
V8_Club
Default LS6 Injectors
I have a '99 C5. So after some research & purchasing some bolt-ons I decided to purchase 28.8lbs/s Injectors to accomodate the extra fuel needed as opposed to the stock 26lbs/s injectors. My question is : Do I need to do any programming changes or the size change is too small to warrant such measures ?
Old Nov 2, 2003 | 07:56 AM
V8_Club's Avatar
V8_Club
Default Re: LS6 Injectors (V8_Club)
Come on people. Someone must know the answer to this question.
Old Nov 2, 2003 | 09:06 AM
Matt69-ZO6's Avatar
Matt69-ZO6
It must a nice weekend in most parts of the country. No one around to answer your question!
TTT :cheers:
Old Nov 2, 2003 | 09:45 AM
gojo's Avatar
gojo
Just a guess that you will need to increase IFR values 5 or 10 %. I would not change anything until after scanning LTFTs.
Old Nov 2, 2003 | 01:19 PM
SpinMonster's Avatar
SpinMonster
offset is stock and the Flow rate has to be adjusted to get the ltft's back near non-positive.
Old Nov 2, 2003 | 01:54 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
I'd scan it and see what LTFTs do. Without program changes the Base PulseWidth will remain the same and therefore greater mass/volume of fuel will flow with the new injectors. PCM will pull fuel to correct - thus reducing LTFTs. Hope this helps some
Old Nov 2, 2003 | 02:17 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: LS6 Injectors (jfpilla)
:iagree: :iagree:
Old Nov 2, 2003 | 02:59 PM
gojo's Avatar
gojo
Default Re: LS6 Injectors (ICULUKN-C5)
Glen, are we related, but you spell your name wrong? :lol:
Old Nov 3, 2003 | 07:49 AM
V8_Club's Avatar
V8_Club
at the risk of sounding stupid , what is ltft ? & IFR ? How can i scan it ? can the predator do any of the former ? :confused: pls help me out. Good info is hard to ocme by & i have still a lot to go to get the lingo down.
Old Nov 3, 2003 | 08:00 PM
gojo's Avatar
gojo
http://ls1edit.slowcar.net/
Read this. It should help a lot.
Old Nov 4, 2003 | 08:20 AM
V8_Club's Avatar
V8_Club
Thanks .I will read through the same tonight. :thumbs:
To LS6 Injectors
