PVC Oil Separator?
Old Oct 31, 2003 | 01:23 PM
Cavallo GT's Avatar
Cavallo GT
St. Jude Donor '07
Default PVC Oil Separator?
Way back when someone posted a fix using a Campbell Hausfield oil separator. At the same time someone posted a pic and brand name of a speed shop separator that supposedly works better. Local speed shops never heard of it. I tried the CH thing. As soon as the element gets saturated, it quits working. 99 C5, too much carbon.
Thanks for any help.
Old Oct 31, 2003 | 01:30 PM
RskyBns's Avatar
RskyBns
Default Re: PVC Oil Separator? (Cavallo GT)
Was it GReddy?
http://www.greddy.com/products/engineparts_frame.htm
Old Oct 31, 2003 | 01:40 PM
TopCat's Avatar
TopCat
Racor makes 'em for boats. Others make 'em for airplanes. I plan to make my own out of a PVC side-out elbow, caps, etc. using plastic or stainless 'brillo pad' material within for the vapor to impinge upon without creating too much pressure drop. Not perfect, but should help quite a bit and fit in the limited area where the hose is currently routed. I don't care to re-route all over the engine compartment to filter out all the vapor. If you want to filter everything, check out the Motor guard 'toilet paper' filters :D
They actually work according to people that use them for compressors. The literature says the pressure drop is low through them, and maybe it will make your Vette smell spring fresh :lol:
Old Oct 31, 2003 | 02:28 PM
Cavallo GT's Avatar
Cavallo GT
St. Jude Donor '07
Default Re: PVC Oil Separator? (TopCat)
Thanks for the help. I'll look into all of the above. Yes, it was the Greddy that was mentioned. If I use the toilet paper thing, can I get one of those air freshners that goes inside the roll? :-)
Old Oct 31, 2003 | 09:25 PM
RSVETTE's Avatar
RSVETTE
Mine still works... :yesnod:
Old Oct 31, 2003 | 09:49 PM
chuckster's Avatar
chuckster
Just take the element out.. Mine catches twice as much now :smash:
Old Oct 31, 2003 | 10:12 PM
c5man99's Avatar
c5man99
Default Re: PVC Oil Separator? (chuckster)
I put a hole in the bottom of the plastic element.........now it catches......NOTHING ! Guess I will replace the element.
Old Nov 1, 2003 | 01:46 PM
white top's Avatar
white top
Default Re: PVC Oil Separator? (c5man99)
I run the CH filter without the filter element catches oil condensation.
Old Nov 1, 2003 | 07:17 PM
c5man99's Avatar
c5man99
Default Re: PVC Oil Separator? (white top)
I checked my set up again............I am missing the O-ring that seals the bowl to the main housing............could this be my problem?
Old Nov 1, 2003 | 08:10 PM
chuckster's Avatar
chuckster
Marc, if there is no seal then it is sucking fresh air into the intake Manifold. It never gets pull the crakcase fumes because the leak is much less resistance..Try to fix the seal..
Heck for $11 just put a new one in and leave the element out..
Old Nov 1, 2003 | 08:37 PM
c5man99's Avatar
c5man99
Charlie, planning on doing that tomorrow.
Old Nov 1, 2003 | 08:50 PM
Sir Sel's Avatar
Sir Sel
I have the CH setup as well and it collects oil. Has anyone bothered to see if your intakes are now oil free?
Old Nov 2, 2003 | 10:31 AM
Cavallo GT's Avatar
Cavallo GT
St. Jude Donor '07
Default Re: PVC Oil Separator? (Sir Sel)
I still get oil. The filter will accumulate 1/4"-1/2" of oil and then no more. As soon as I clean the element, it collects another like amount. You guys that removed the element, Did you replace the black plastic thing that looks like a gear? I think that plays a part in separating the oil. Mine fell down behind the damn battery into the lower fender well! I'm going to go find it today and remove the element but leave the black thing.
Old Nov 2, 2003 | 10:52 AM
2001 Red Coupe Bandit's Avatar
I did this mod myself, still use te original have the filter and after 2.500 it still works. It catches a teaspoon or 2 when I empty it every 4-6 weeks.
Some say they lost power with it, but that sounds pretty starnge to me. Look at my times, it isn't slowing me down and I see it works so I might as well keep running it. :D
Old Nov 2, 2003 | 05:25 PM
WRK CAR's Avatar
WRK CAR
Default Re: PVC Oil Separator? (2001 Red Coupe Bandit)
Mine still works fine with the filter in it.
Old Nov 2, 2003 | 08:04 PM
c5man99's Avatar
c5man99
Default Re: PVC Oil Separator? (WRK CAR)
I got a new unit today.........needed to replace white filter and replace missing o-ring. Has anybody tried teflon tape on the bowl threads? I'm curious, how do you all remove the excess oil.......unscrew the bowl or use the shrader valve? Do you through out the accumulated oil or, like me, dump it back in the oil fill.
To PVC Oil Separator?
