Shift light info, please.....
Old Nov 4, 2003 | 08:33 PM
WiseGuyZ's Avatar
WiseGuyZ
Default Shift light info, please.....
Where can I buy a shift light for my Z06.... I've heard harlan is good but anyother suggestions???? THANKS
Old Nov 4, 2003 | 09:40 PM
Dave@808's Avatar
Dave@808
Default Re: Shift light info, please..... (WiseGuyZ)
Check out Rick at Raptorperformance.com.......The raptor lite rocks! :yesnod:
Old Nov 4, 2003 | 09:50 PM
Patches's Avatar
Patches
Harlan is good but I like the Raptor because it's significantly smaller and much easier to program. Programming is 3 dip switches you set once for the engine type and 2 rotary switches where you can set and change the activation RPM in seconds any time you need to.
Here's my Raptor
I've got it mounted on the A-pillar
Mine has blue LED's but you can get them in various colors. Go to http://www.raptorperformance.com
Incidentally, I made mounting brackets for friends with Harlans in the past o replace the cruddy one that comes with it. It's on the right in the pic below next to the Raptor bracket.
For tach wire hook up info go to Flyin' Brian's thread below:
http://forums.corvetteforum.com/zerothread?id=619162
Best of luck.
:cheers: :seeya
Old Nov 4, 2003 | 09:55 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
The Harlan works great and is priced right. :thumbs: If you don't mind taking a chance of not getting it after paying for it:rolleyes: and having your numerous e-mails going unanswered,:rolleyes: then this would be a good choice. :cheers:
Old Nov 4, 2003 | 10:02 PM
corvette184's Avatar
corvette184
Default Re: Shift light info, please..... (Racer44)
i just ordered a raptor light from nitrous4less.com and i will install friday night...i will let you all know my opinion :thumbs:
Old Nov 5, 2003 | 10:55 AM
boost2much's Avatar
boost2much
Default Re: Shift light info, please..... (corvette184)
Get a Raptor shift light. I guess any other shift light would work also but I'm very satisfied with my light and they had great customer service when I broke my mounting bracket, sent me replacement for free asap :thumbs: :cheers:
Old Nov 5, 2003 | 11:00 AM
Patches's Avatar
Patches
Default Re: Shift light info, please..... (boost2much)
I had a great customer service experience too. My light wasn't working properly and he overnighted a replacement, no questions asked. Quality is excellent too. :yesnod:
Old Nov 5, 2003 | 03:44 PM
Don Baldwin's Avatar
Don Baldwin
I'm with boost2much & Patches. Raptor is great and the customer service can't be beat. I have had no problems, just a question and Rick answered right away.
Old Nov 5, 2003 | 04:52 PM
GraveDigger's Avatar
GraveDigger
Raptor is great, I have one. I bought it through Extreme because Raptor does not take credit cards and Extreme does. :yesnod:
Tod :seeya
Old Nov 5, 2003 | 05:41 PM
alexWS6's Avatar
alexWS6
Default Re: Shift light info, please..... (GraveDigger)
I've got a raptor light in transit to me. Going to install Friday.
Patches- does it come with everything you need to mount it where you did?
Old Nov 6, 2003 | 01:49 PM
z-u-later's Avatar
z-u-later
Default Re: Shift light info, please..... (alexWS6)
Thanx,
For the info..
Old Nov 6, 2003 | 02:24 PM
Patches's Avatar
Patches
Alex, it comes with two different brackets. They are so similar, though, that I think most choose the one I used because it's the sturdier of the two. No screws came with it so you'll need to find those yourself if you plan to mount it that way. I just cleaned the plastic really well with denatured alcohol and used 3M double-stick tape to mount the bracket. No drilling required. The bracket is very secure using the tape and I've popped the light in and out of it many times to play with the settings.
To Shift light info, please.....
