What Harness used for shift light
Old Nov 4, 2003 | 10:30 PM
z-u-later's Avatar
z-u-later
Default What Harness used for shift light
I've seen a few posts but cant find the one for the harness on the drivers side does any one know where the tach wire harness is located on the drivers side? Outside of going threw the passengerside firewall? :skep:
[Modified by z-u-later, 9:31 PM 11/4/2003]
Old Nov 4, 2003 | 11:12 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: What Harness used for shift light (z-u-later)
cant help you with under the dash.... if you goto the ECU in the fender.
97 & 98 models, find the white wire, pin #35, of the blue connector.
99 - 04 models, find the white wire, pin # 10, of the red connector.
Old Nov 4, 2003 | 11:16 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: What Harness used for shift light (ICULUKN-C5)
I know there is another post on this somewhere but I can't find it right now. Here is one of them though. http://forums.corvetteforum.com/zerothread?id=380488
Old Nov 4, 2003 | 11:18 PM
Racer's Avatar
St. Jude Donor '11
Default Re: What Harness used for shift light (Racer44)
Here is the other one. http://forums.corvetteforum.com/zerothread?id=619162
To What Harness used for shift light
