Home made jacking pads???
Old Nov 6, 2003 | 03:41 PM
Colorado Chuck's Avatar
Colorado Chuck
Default Home made jacking pads???
I know many members have made their own jack pads using hockey pucks, and evidentally use eye bolts to hold them in place. Question is, do I use one puck, or two, to get the proper clearance? Also, how is the eye bolt fastened to the puck?
I know you can buy these things, but I agree with those who say to save your money for the important things that you can't make!
Old Nov 6, 2003 | 05:39 PM
Karl_in_Chicago's Avatar
Karl_in_Chicago
Default Re: Home made jacking pads??? (Colorado Chuck)
Step by step with pictures: http://www.97vette.com/howto/liftpads/index.html
Old Nov 6, 2003 | 05:52 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
My car is lowered... and even with my harbor frieght low profile aluminum racing jack... I can only use one puck... but one puck has always been enough...I just made an extra set for the car yesterday.... 4 pucks @ 99 cents... 4 one inch outside diameter eye bolts..@ 44 cents each... total
$5.72 plus tax. I cut off the first few threads so the threaded area was less than one inch... ( the thickness of a puck )
Old Nov 6, 2003 | 06:50 PM
Colorado Chuck
Default Re: Home made jacking pads??? (Karl_in_Chicago)
Thanks a bunch for your response, guys. Time to go shopping, before the time comes when I have to jack this thing up. (I do have a pit, but that won't help you change a tire...)
Old Nov 6, 2003 | 08:54 PM
Monster231's Avatar
Monster231
I just stick a 2X4 under there, never had a problem
Monster231's Avatar
Monster231
I just stick a 2X4 under there, never had a problem :party:
Old Nov 6, 2003 | 09:04 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Just so you know, I've used a single puck without the bolt with no problems. I just jack until it's CLOSE to the frame, triple check the way the puck is aligned to make sure it's touching all frame and no body, then finish jacking it up.... zero problems so far and I've done it at least 20 times.
Old Nov 6, 2003 | 09:35 PM
Colorado Chuck
Default Re: Home made jacking pads??? (diynoob)
I have always felt that if I needed to jack it up that I could just use some wood, and perhaps nothing since my jack would go up inside without touching the body. At some time I am going to need tires, and I just shudder at the damage the typical tire store could do with their lift.
Old Nov 7, 2003 | 08:12 AM
MSIP's Avatar
MSIP
Follow these steps: http://www.97vette.com/howto/liftpads/index.html
As I recall, I could not find those exact eye bolts, but I used some 1/4" longer. They work fine.
[Modified by MSIP, 7:12 AM 11/7/2003]
Old Nov 7, 2003 | 09:08 AM
2K1TRVert's Avatar
2K1TRVert
Cruising
Default Re: Home made jacking pads??? (MSIP)
:iagree:
That's what mine look like.
Old Nov 7, 2003 | 04:40 PM
denali's Avatar
denali
St. Jude Contributor
Default Re: Home made jacking pads??? (2K1TRVert)
Yep! I've got 4 just like yours.
:iagree:
Old Nov 8, 2003 | 01:56 PM
Tracy's Avatar
Tracy
Default Re: Home made jacking pads??? (denali)
Single puck thinkness works just fine. I would think that 2 pads would interfere with most lift arms by being too close to the floor, thus getting in the way of the arms and annoying the surly tire tech who didn't really want to use your silly hockey pucks to protect your "baby" in the first place, because he's lifted a dozen C5's at his tire shop and hasn't hurt a thing yet (except scratch the rockers some where it can't be seen....). I mean, you can picture how this scenario would play out!! I would stick to a single puck so you'll KNOW it will work with nearly any lift.
To repeat, single thickness works fine. And I made my pucks with wooden t-***** (modified drawer pulls from H. Depot) for about $6.
Old Nov 8, 2003 | 09:50 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Home made jacking pads??? (Tracy)
One for me!
Old Nov 8, 2003 | 10:29 PM
Colorado Chuck
I am going to take Tracy's advice and go with one. The measurements I took indicate one should be enough and I don't want to antagonize that surly tire tech. Besides, pucks out here are $2, so I save $8!!!
Thanks again to everyone.
Old Nov 9, 2003 | 12:00 PM
rbz06's Avatar
rbz06
Amazing that they charge 75 bucks for jacking pucks online. Thanks for the great idea! :party: :hurray:
Old Nov 10, 2003 | 01:41 PM
Colorado Chuck
One last comment. When I got the eye bolts I tried both the 1/4 as well as the 5/16, and the heavier ones fit better so I used them. I also added a 2" fender washer between the eye and the puck, glued on with Zoop. The single puck works great (and .99 at Gart Sports!)
To Home made jacking pads???
