help*stupid oil drain plug direction question
Old Nov 8, 2003 | 03:41 PM
Mirek's Avatar
Mirek
Default help*stupid oil drain plug direction question
Man is that OIL plug in there !! before I bust out the pry-bar I better make sure i'm turning it right the correct direction.....with my feet facing the front of the car (on my back) i'm turning (or trying to turn) that plug clockwise ( to my left)
Am i good?
Old Nov 8, 2003 | 04:01 PM
mnotx's Avatar
mnotx
Default Re: help*stupid oil drain plug direction question (Mirek)
It's like almost every other plug. If you are facing it from below, counter-clockwise to take out. Clockwise to install.
Old Nov 8, 2003 | 04:10 PM
Mirek's Avatar
Mirek
Default Re: help*stupid oil drain plug direction question (mnotx)
That does not answer my question.
I want to make sure that the upside down text on the pan is not messing me up(direction wise)
Just to be safe -- it sure it stuck.
Old Nov 8, 2003 | 04:17 PM
mnotx's Avatar
mnotx
I guess I am not sure of your question. Your orientation does not matter. If you are taking the plug out, it unscrews counter-clockwise.
Old Nov 8, 2003 | 04:19 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
lefty loosy..... Righty, tighty......
turn it left to loosen.... turn it right to tighten...
left is counterclockwise
right is clockwise. all looking at the bolt head
Old Nov 8, 2003 | 04:21 PM
Karl_in_Chicago's Avatar
Karl_in_Chicago
Am i good?
That seems to be in conflict. If you are on your back with your feet facing the front of the car AND you turn it left then that is counter-clockwise (which IS what you want), not clockwise (though it makes no diff where your feet are facing, just that you are on your back). As the other responder said, counter-clockwise is the way to go to loosen. For most of the fasteners on the car the old adage "Righty-tighty, lefty-loosey" won't let you down. If you are really, really, not sure OR you are afraid it's going to break for some reason then do yourself a favor and take it to the dealer and pay the ~$60 for an oil change there. If the plug breaks or the pan strips you can make it their problem, then do it yourself from then on.
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
You mean counter clockwise (to your left). That would be correct. Turn it to your left.
Old Nov 8, 2003 | 04:31 PM
gojo's Avatar
gojo
On your back, with the bar in the 3 oclock position, pull the bar.
Old Nov 8, 2003 | 04:54 PM
Cajun99's Avatar
Cajun99
...counter-clockwise to take out. Clockwise to install.
Yes it does :yesnod: and it doesn't matter if you're laying down, standing up or upside down with one hand behind your back :D The plug will always tighten clockwise and loosen counter-clockwise. :cheers: :thumbs:
Old Nov 8, 2003 | 05:16 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Am i good?
Nothing personal Mirek, but I believe you are a candidate for a professional oil change.
Old Nov 8, 2003 | 07:37 PM
rhoeven's Avatar
rhoeven
And you work for Daimlerchrysler ?? :lol: :lol: :lol: :smash: :smash: :smash:
Old Nov 8, 2003 | 07:55 PM
wrustywrench's Avatar
wrustywrench
Default Re: help*stupid oil drain plug direction question (rhoeven)
put end of wrench towards passenger side of car,,,,pull towards drivers side....if you look at it from the front facing facing the plug,,,,turn it counter clockwise.......I mean pull down on wrench towards floor towards drivers side....I will do it for 10 bucks,,, :party:
Old Nov 8, 2003 | 09:08 PM
Dope's Avatar
Dope
Resident moron
I guess we should assume that you didn't do the work in your sig by yourself, eh?
Dope
Old Nov 8, 2003 | 09:55 PM
Shortimer's Avatar
Shortimer
Default Re: help*stupid oil drain plug direction question (Dope)
Seems like the real problem here is the last time the oil was changed the drain plug was over tightened. It should be snug but not too tight. I'm sure there is torque spec in the service manuals. It's not listed in the owners manual. :chevy
Old Nov 8, 2003 | 10:05 PM
knewblewkorvette's Avatar
knewblewkorvette
Default Re: help*stupid oil drain plug direction question (Karl_in_Chicago)
:iagree: be sure and replace the plug with a magnetic plug, $5 is cheap insurance to catch any metal particles.
Old Nov 9, 2003 | 03:16 AM
markcz's Avatar
markcz
:skep: You guys are giving me a headache.
While standing upright, put a socket on a ratchet, now hold the socket in your left hand and (while using your right hand to turn the ratchet) flip the switch so the ratchet is going in the direction that you need it to (righty tighty, lefty loosey). Now you can lay on your back, stand on your head, or hang from the ceiling, and the ratchet will still be going the way you need it to.
:cheers:
Old Nov 9, 2003 | 09:05 PM
Evil-Twin's Avatar
Evil-Twin
Am i good?
I could be worse Mirek.... you could be a brain surgeon. :blueangel: :) :reddevil
To help*stupid oil drain plug direction question
Old Nov 9, 2003 | 09:10 PM
Monster231's Avatar
Monster231
Default Re: help*stupid oil drain plug direction question (Evil-Twin)
Dont forget to put oil back in once you have loosened it. :lolg:
sorry couldnt resist :reddevil
Old Nov 9, 2003 | 09:14 PM
Evil-Twin's Avatar
Evil-Twin
Default Re: help*stupid oil drain plug direction question (Monster231)
I see you have one of those devils on your shoulder, like me... Monster231
Old Nov 9, 2003 | 09:58 PM
SQEZN BI's Avatar
SQEZN BI
Have your friend hold the rachet , now if standing in front of car turn car counter clockwise. Devil on both shoulders. :reddevil :cool: :reddevil
