c5 water injection?
I think I will even have to have on of those kits. Thanks for finding it Moundir and sharing it with us all...Also Shelby's kit....The Forum is a great site for all of us to share our exsperiences and problems. :hurray:
I've never figured out why some people are so eager to try to make another look inadequate or foolish. We really don't need this on the Corvette Forum.
Jim Helm
Again, sorry for causing a ruckus. :bb
Not nice! Everybody here is entitled to ask a question here without being ridiculed
The SMC kit is very good, but I wanted to run Methanol and spray more volume than the SMC kit could support (the SCM kit was not methanol compatible at the time, but I think they may have better upgraded kits available now)
I now have a completely home built kit, but still use the SMC controller. The kit basically consist of the following:
-Shurflow diaphragm pump (capable of pushing over 300psi in my setup, these pumps are typically used as the water pressure system in boats and RVs and I was familiar with them from working on my boat)
-Small intermediate tank (this suppresses surging that is inherit in a diaphragm pump)
- Stock washer tank as reservoir
- 2 300psi stainless steel capable solenoids
- 2 m10 fine mist cone nozzles (these can be purchased at http://www.mcmaster.com)
- Stainless steel braided high pressure Teflon lines
- misc fittings, pressure switches, relays
- SMC controller box
The nozzles sit in my custom air bridge between my maf and the TB. The first nozzle is set to come on at 3psi and the 2nd comes on about 6psi (controls under my dash allow me to control turn on points and pump speed). I also have LEDs mounted in my pillar pod to show when the various nozzles are on and if the pressure is high enough. It also shows me when the tank is getting low. This is all custom, but it was very easy to setup (the SCM controller provides most of this).
Here are a few pictures to give you an idea of how it is setup. The pump assembly is mounted on the front driver side wheel well access panel.
http://us.f1.yahoofs.com/users/3f121...MDxr_AjjyeMKFH
This is not a great pic, but it shows the location of the two nozzles.
http://us.f1.yahoofs.com/users/3f121...MDxr_ANMHbVIqj
Anyway, I can't imagine this being much benefit on a non boosted car, but you never know until you try it. You can think of it as being very similar to running race gas. You won't see any benefit unless you are actively getting KR or you tune the car to run more aggressive timing or higher cylinder pressure.
I'm about to pull my heads for the first time this week, so it will be interesting to see how clean the pistons are.
[Modified by QuickSilver2002, 10:26 PM 11/9/2003]
KEITH :thumbs: :thumbs: :hurray:
