Belleville washers?
Nov 10, 2003 | 04:13 PM
Belleville washers?
I bought 2 disc kits for the rear gears from GM Direct. It is supposed to, according to the GM book, contain the washers. Anyone know where to get them?
Nov 10, 2003 | 04:25 PM
Re: Belleville washers? (jfpilla)
http://www.bellevillesprings.com/
I have used these in the past on some of our gov't jobs where I work, but never for personal use.
Nov 10, 2003 | 09:30 PM
Anyone know about the spring washers in the rear end?
Nov 11, 2003 | 08:56 AM
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I have used these guys in the past;
http://www.thomasregister.com/olc/03546694/home.htm
http://www.bokers.com/
http://www.coldheader.com/
There are more.
You can go to a local dealer and look at a parts blow-up if you ask nicley :D
I have yet to work on a C5 rear and don't have the service manual in front of me.
:cheers:
Nov 11, 2003 | 09:49 AM
St. Jude Donor '13
#1 is called a bevell "ring"...P/N 12369463...Does not come with the clutch pack kit.The part that you thought was the washer #2,that came with the clutch pack is the friction disk :cheers: Been there,done it :D
[Modified by C-5 TECH, 9:51 AM 11/11/2003]
[Modified by C-5 TECH, 2:35 PM 11/11/2003]
Nov 11, 2003 | 02:13 PM
Re: Belleville washers? (C-5 TECH)
Thanks for all the responses. C5 Tech, I just got off the phone with GM. They don't include #1 in your diagram, in the kit. It's a spring washer. They are not sure they sell them either.
Nov 11, 2003 | 02:39 PM
St. Jude Donor '13
#1 is the bevill,you can get it from GM Parts Direct.com...#12369463...I have replaced a few,I have seen them break in half :cheers:
Nov 11, 2003 | 02:57 PM
I just emailed a photo of the part. That # is for the retainer clip. I appreciate your help.
Nov 11, 2003 | 03:48 PM
St. Jude Donor '13
As per the service manual and the photo:
Install the clutch pack - right to the case - right.
Install the separator plates (4).
Install the friction discs (3).
Install the friction disc (thick) (2).
Install the bellville washer (1).
Nov 11, 2003 | 05:17 PM
The Belleville washer is it. Now to get 2 of them. May have to have them made, unless someone has a blown rear and wants to get rid of them.
