Redline Water Wetter
Old Nov 11, 2003 | 10:05 AM
57xray's Avatar
57xray
Default Redline Water Wetter
Has anyone used Redline Water Wetter and what's your opinion? Is it safe to use it the C5 cooling system?
Thanks :auto:
Old Nov 11, 2003 | 10:30 AM
2001 Red Coupe Bandit's Avatar
Default Re: Redline Water Wetter (57xray)
I have used it and a buddy has used cases of it in his and others cars. It is totally safe. I used Red Line Oil in my car also :D
Old Nov 11, 2003 | 11:18 AM
c5chris's Avatar
c5chris
Im planning to use this with just distilled water in my radiator. A friend competes in various road races (Gamblers Run, Silver State, etc.) and says that Water Wetter and water is sufficient enough to cool his 2002 Z06 running an average of 130mph for the duration of the event. On my next coolant change, i'll eliminate Dexcool from my car.
Old Nov 11, 2003 | 12:11 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Redline Water Wetter (c5chris)
I used it in my 87 vette and it worked well. May switch to Red Line for the C5. :thumbs: :cheers:
Old Nov 11, 2003 | 02:18 PM
StoutMan's Avatar
StoutMan
Default Re: Redline Water Wetter (LittleBoyBlu99)
Redline Water Wetter and Oil is all I use... :D
Old Nov 11, 2003 | 02:21 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
Default Re: Redline Water Wetter (JIJ)
I used it..saw no difference temperature wise. Put it my Jeep..saw no difference there either :confused: I also live in Phoenix :(
Old Nov 11, 2003 | 03:19 PM
Nitro-C5's Avatar
Nitro-C5
Moderator
St. Jude 15 Year Donor
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '08-'25
Default Re: Redline Water Wetter (Scratch)
I use it and works great...best results to use with distilled water though.
Old Nov 11, 2003 | 04:38 PM
Mitch Alsup's Avatar
Mitch Alsup
True: glycol does not have the specific heat capacity of water. So a water + water-wetter can take more heat than (water+clycol) + water wetter.
Old Nov 11, 2003 | 04:58 PM
FKING1's Avatar
FKING1
Default Re: Redline Water Wetter (Mitch Alsup)
Water Wetter with water will aid in heat transfer, but, the engine running temperature is controlled by the thermostat. Unless you change that the engine will run at the same temp. I have a 178 therm and fan controller. The Wetter made no diff in running temp.
Fred K.
To Redline Water Wetter
