Exide Orbital Battery Install (^!@#%**&)
Old Nov 17, 2003 | 06:21 PM
XmentalPilot's Avatar
XmentalPilot
From: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
Default Exide Orbital Battery Install (^!@#%**&)
I bought an Exide Orbital (like an Optima) today could not get the factory battery cables to make solid contact with the side posts... was very frustrating. Ended up returning the battery after the parts store folks and I spent an hour plus screwing around.
Anyone out there have a similar experience with non-delco replacement batteries??
The Delco battery has a much bigger open space where the battery post can mate to the stock battery cable... I should have gone with an Optima in the first place... any problems getting the Yellow Top to hook up??? Oh well... ya gotta learn something new every day!!!
[Modified by XmentalPilot, 3:21 PM 11/17/2003]
Old Nov 17, 2003 | 06:33 PM
leaftye's Avatar
leaftye
Default Re: Exide Orbital Battery Install (XmentalPilot)
I installed the Optima Red Top that I bought at CostCo about a month ago, and it fit just fine...actually, I was afraid it was a bit small, but it fits great, and works great inspite of the freezing temps in the morning.
Greg_E's Avatar
Greg_E
I had no problems installingthe Optima yellow top. :thumbs:
Old Nov 17, 2003 | 06:59 PM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Default Re: Exide Orbital Battery Install (Greg_E)
I have the Exide Orbital in my car. I will check the part number if you want me to look.
Old Nov 17, 2003 | 07:40 PM
Oldvetter's Avatar
Oldvetter
I replaced my DELCO with a Champion XLT (AGM Battery) size/number DT35/CHXDT35 made by Exide. Got it at SAMS Club for $90-95. It has 690 CCA, 850 CA, a 36 month free replacement and free jump-start, and a 108 month limited warranty.
I had no problems installing the battery or cables.
Old Nov 17, 2003 | 09:10 PM
LS1LT1's Avatar
LS1LT1
Default Re: Exide Orbital Battery Install (Oldvetter)
What's the weight on some of these batteries (Optima red or yellow)...are any of them lighter than the factory Delco?
Any chance of using a lightweight battery such as a Dynabatt or Hawker Genesis in a C5 or are there just too many electronic items in the car for a such a tiny battery (13 pounds) to handle.
Old Nov 17, 2003 | 09:30 PM
leaftye's Avatar
leaftye
Default Re: Exide Orbital Battery Install (LT1LS1)
I can only say that it still felt really heavy, like the battery that was in there before. I bought it solely to eliminate the risk of battery leakage.
To Exide Orbital Battery Install (^!@#%**&)
