DTC code help needed asap...
Old Nov 18, 2003 | 02:24 PM
lawman34203's Avatar
lawman34203
St. Jude Donor '13-'14
Default DTC code help needed asap...
I keep getting a P0410 code and the check engine light comes on. I re-set it but it usually comes back in a couple days. What is the problem and what is a quick fix for this. Should this be covered under the extendned warranty?
Old Nov 18, 2003 | 03:23 PM
Kenny94945's Avatar
Kenny94945
Default Re: DTC code help needed asap... (lawman34203)
Code is: AIR System
Could also set 1415 or 1416 which indicate which bank triggers 0410. Also other codes could be listed.
You could start by looking at the AIR pump relay and AIR solenoid relay.
Of course, maybe AIR pump fuse is intermittent.
There are 28 steps in the manual for diagnosis.
Good hunting.
