Interesting find regarding octane index....
Old Nov 18, 2003 | 06:04 PM
Colorado Chuck's Avatar
Colorado Chuck
Default Interesting find regarding octane index....
Some time back, I requested and received from Chevy free data about the 1999 Corvette. Included were some 35 pages of "Manufacturers Motor Vehicle Specifications". On page 3 under Engine- General for Fuel antiknock index (R+M)/2 Chevrolet lists 87.
Not 91 or 92, but 87.
Down below there is a posting from someone who used 89 octane instead of 91, with good results. Most of the replies to that posting agree with him.
I know what the manual says, but the MVMA says 87.
There are two ways to express a gasolines octane number. Actually 3)
RON means Research Octane Number. MON is for Motor Octane Number. What we see on the pumps is the sum of those two, divided by two, or (R+M)/2
For what it's worth, I am switching to 87 octane, which at my altitude (8800') and therefore cooler temperatures, should work just fine. During the winter I could probably use regular up here!
Old Nov 18, 2003 | 06:14 PM
RWhite's Avatar
RWhite
Default Re: Interesting find regarding octane index.... (Colorado Chuck)
I bet if you autotap it after a tank of 87 you will be on the low octane table. :yesnod:
Old Nov 18, 2003 | 06:18 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Interesting find regarding octane index.... (RWhite)
R White - here's an interesting thread on Octane tables http://www.efilive.com/forum/viewtopic.php?t=282 FWIW.
Old Nov 18, 2003 | 06:29 PM
Mike Mercury's Avatar
Mike Mercury
but this deals with a computer controlled engine that can retard spark automaticaally. I don't know of any instance where anyopne here claimed the C5 "wouldn't run" or would "choke & gag" on lower octane gasoilne.
Before computer controlled engines... octane below the optimum engine tuning could cause problems. 87 octane will not damage the LS1, but the PCM will detune the engine to compensate.
Why buy a sports car... and then intentionally reduce the engines power output ???
Old Nov 18, 2003 | 06:38 PM
RWhite's Avatar
RWhite
Default Re: Interesting find regarding octane index.... (Mike Mercury)
Thanks Binks...
I have my tables set very close, I get 2 degs of retard at the most.
I also run good gas.
Old Nov 18, 2003 | 07:19 PM
AtHomeSoda's Avatar
AtHomeSoda
Good Point... and I just got an idea from a certified mechanic... he tells me that what ever octane gives the best gas mileage will also be the one that gives you the most power... So if you make the same drive, under the same conditions, with cruise control on... you can see which works better........
:party: :steering: :auto: :hurray: :chevy :cheers: :eek: :skep: :leaving:
To Interesting find regarding octane index....
