How do I remove?
Old Nov 18, 2003 | 09:48 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default How do I remove?
The hose fitting from the slave cylinder? Is there a trick. I tried the NAPA hose removing tools for fuel lines, but no go.
Old Nov 18, 2003 | 11:20 PM
Chris@SD's Avatar
Chris@SD
Default Re: How do I remove? (Budman78)
I actually use some kind of ford clutch tool and it works great! Pretty much, you need to push the plastic collar into the fitting and pull the pieces apart. It is a bear sometimes, but just keep trying. It will come.
Good luck,
Old Nov 19, 2003 | 01:53 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: How do I remove? (Chris@SpeedDemon)
Good help is just a ?? away. :thumbs: :cheers: :yesnod: :yesnod:
Old Nov 19, 2003 | 08:56 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
Default Re: How do I remove? (LittleBoyBlu99)
Used a pair of needle nose and pushed the white bushing in and the hose pulled right out. Thanks.
To How do I remove?
