Low Washer fluid light
Old Nov 19, 2003 | 02:12 PM
mdhmi's Avatar
mdhmi
Default Low Washer fluid light
My low washer fluid light is coming on. And yes I have added washer fluid.. Any ideas on how to fix this?
Thanks,
Mark
Old Nov 19, 2003 | 03:05 PM
TeeJay's Avatar
TeeJay
Default Re: Low Washer fluid light (mdhmi@yahoo.com)
Mark,
The connector for the sensor is easy to dislodge. Confirm that it isn't loose and (probably) wait an ignition cycle or two to see if the warning clears.
Old Nov 19, 2003 | 03:09 PM
Shortimer's Avatar
Shortimer
Default Re: Low Washer fluid light (TeeJay)
Saw another post not long on this same problem. If you do a search you're sure to find several suggestions. :chevy
Old Nov 19, 2003 | 03:49 PM
BlueDragon's Avatar
BlueDragon
That little float thingy can spin on you. Make sure that little flat on the plug/sensor is facing down. If you pull it out (watch out all the fluid will follow) you will see what I mean. It comes out really easy, and can sping upside down just as easy!
jer
Old Nov 20, 2003 | 09:38 PM
BlueDragon's Avatar
BlueDragon
Default Re: Low Washer fluid light (BlueDragon)
Just double checked mine and the white plastic sensor is keyed to the fluid tank. There is a flat on that that should be UP to key to the tank!!!
Jer
Old Nov 20, 2003 | 10:26 PM
Dennis Wilson's Avatar
Dennis Wilson
Mine comes on after the car sits on my driveway with the nose lower than the rear It goes off the next time you start it or you can reset it. ;) :cheers:
To Low Washer fluid light
