Rattle when shutting off engine
Old Nov 20, 2003 | 03:41 PM
C5XP's Avatar
C5XP
Default Rattle when shutting off engine
I noticed a rattle/knock when I shut off the engine. It does it about everyother time. Its been doing it for awhile now. I was wondering if anybody has ever had this problem. Any advise. Thanks for the help. :cheers:
Old Nov 20, 2003 | 03:50 PM
EricG33's Avatar
EricG33
Default Re: Rattle when shutting off engine (C5XP)
A fellow Okie......cool. Anyway, if your car is a six speed its your clutches in your tranny making the noise most likely. Try pushing your clutch in next time you shut if off and see if this fixes your "problem". It's actually a very common issue with 6 speeds. Regards, Eric :seeya
Old Nov 20, 2003 | 04:08 PM
SFVetteman's Avatar
SFVetteman
It probably would not hurt to due the decarb procedure to get rid of any carbon deposits that are usually the cause of the diesel like rattle. It's worth it if only for the reaction of your neighbors, as it creates a lot of smoke and they will think your car is heading for the last roundup :p: :lolg:
Old Nov 20, 2003 | 05:38 PM
1 BAD C5's Avatar
1 BAD C5
Default Re: Rattle when shutting off engine (SFVetteman)
Leave clutch pressed in while you shut your engine off. Had the same thing with mine, totally normal believe it or not. :thumbs:
Old Nov 20, 2003 | 10:28 PM
DsC5's Avatar
DsC5
Default Re: Rattle when shutting off engine (1 BAD C5)
:iagree:
Old Nov 21, 2003 | 06:49 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
This is a C5 COMMON complaint for new MN6 owners. The noise is normal and only happens when you shut the engine down with the trans out of gear. Try shutting it down with the clutch pushed in. It should not make the noise.
I do not believe that there is anything wrong with your clutch or trans.
BC
Old Nov 21, 2003 | 07:09 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Default Re: Rattle when shutting off engine (Bill Curlee)
Yup - its normal (unfortunately..) Press clutch in while shutting down - no noise. Enjoy!
Old Nov 21, 2003 | 07:43 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Default Re: Rattle when shutting off engine (DsC5)
Leave clutch pressed in while you shut your engine off. Had the same thing with mine, totally normal believe it or not. :thumbs: :iagree:
Just hold in the clutch @ shut off... :iagree:
Old Nov 25, 2003 | 08:58 AM
C5XP's Avatar
C5XP
Default Re: Rattle when shutting off engine (Dr.Ron)
I tried shutting it off with the clutch pedal held in and the noise goes away. It still does it when the car is out of gear and if the clutch is not in. Is this really normal or is there something wrong? I have had the car for awhile and somebody told me that it was normal but I wasnt exactly sure. Its embarrassing when your with some friends and you shut the car off and it makes that noise. What exactly is causing it? Thanks for the help. :steering:
Old Nov 25, 2003 | 09:39 AM
vetdude's Avatar
vetdude
Normal with the motor in the front/trans in the rear technology - my Porsche 944 did the same thing years ago. I've been told by a tech that it's caused by the "lash" in the torque tube between the motor and the trans.
Old Nov 25, 2003 | 09:45 AM
C5XP's Avatar
C5XP
Default Re: Rattle when shutting off engine (vetdude)
Could there be something wrong with one of the coupling inside the torque tube? :confused:
Old Nov 25, 2003 | 11:32 AM
AJP03CoupeNJ's Avatar
AJP03CoupeNJ
Hey C5XP--- First time I heard it was in the dealer parking lot with 3miles on the car...My baby was brand spanking NEW !!!... Ignore it or throw in the clutch...... :cool:
Old Nov 25, 2003 | 12:17 PM
Monster231's Avatar
Monster231
totaly normal. when building a sports car, some compromises are made. Lighter stronger parts, or quite smooth ones. That why there is some clutch chatter, i belive it the throw out bearng disengagin from the pressure plate
Old Nov 25, 2003 | 12:42 PM
WGreen's Avatar
WGreen
Cruise-In I Veteran
Default Re: Rattle when shutting off engine (Monster231)
Takes a while for the marbles to quit spinning in the coffee can. :lol:
Old Nov 25, 2003 | 05:34 PM
jedicowboy's Avatar
jedicowboy
My A4 has done that when I had a crappy tank of gas.
Old Nov 25, 2003 | 05:41 PM
king_pin's Avatar
king_pin
St. Jude Contributor
:iagree:
Old Nov 30, 2003 | 01:17 PM
C5XP's Avatar
C5XP
Default Re: Rattle when shutting off engine (king_pin)
Thanks for the information. Clutch is on the way. The modding will now begin :reddevil The car is still stock but not for long... :steering:
To Rattle when shutting off engine
