I just removed this screen and the car idle high ...
I did a relearn and car idle high (2700 rpm) when rolling and idle not stable (up and down from 1500 - 1800 rpm) when stop completely.
This is the front screen.
Thanks http://content.madirect.com/img300/fr39.jpg
***BTW, if turn on AC then everything is normal but I don't wanna run my car with AC on all the time:D
Re: Will this messes up air flow sensors? (mike76002)
Heard that this could happen, which is why I still have my screen :D Might look for vacuum leaks, though, since you have to disassemble the air intake to get to the MAF and remove the screen. Did you do any porting while in there, or just remove the screen?
Re: Will this messes up air flow sensors? (TopCat)
