Fuel Gauge Problem!!!
Old Nov 25, 2003 | 10:29 PM
Vegas Vette's Avatar
Vegas Vette
Default Fuel Gauge Problem!!!
I was driving to work this morning and my fuel gauge just droped to empty. It did this to me about 6 months ago. Can anyone tell me what might the problem be and does it need to go to the dealer for repair? I work at a derest Air Base in CA so you can guess I freaked out being in the middle of nowhere. Sure could use some insight on this problem.. :banghead: :confused:
Old Nov 25, 2003 | 11:10 PM
illmac77's Avatar
illmac77
CI 7-8 Veteran
CI 8 Car Show Winner
St. Jude Donor '07
Default Re: Fuel Gauge Problem!!! (razor2430)
Its the fuel sending unit inside the gas take that is messed up, reset your DIC again Ray, ive read where its been replaced and the same problem came back.
Old Nov 26, 2003 | 12:34 AM
Vegas Vette
Default Re: Fuel Gauge Problem!!! (illmac77)
Hey Mike I reset the DIC again today I'll see if it does it again. talk to you soon.. :cheers:
Old Nov 26, 2003 | 01:11 AM
Tom337's Avatar
Tom337
My gauge did this three different times, I was told to try a fuel additive called Techron,sold at Wallmart.I also started running Sunoco 94 octane gas.The problem has gone away.Good luck with yours.
Old Nov 26, 2003 | 02:46 AM
jfss3bat's Avatar
jfss3bat
5th Gear
Had the same problem with my fuel gage about 4 months ago. I added some fuel system cleaner (can't remember the brand) and haven't had a problem since. From what I've read the fuel level sensors are suseptible to some type of fouling that causes them to malfunction.
John (ATC USN Ret.)
Old Nov 26, 2003 | 06:05 AM
vettenuts's Avatar
vettenuts
Default Re: Fuel Gauge Problem!!! (jfss3bat)
There are two bulletins out on this, and the last software update for the PCM for this problem was released last June. One of the recommendations in the bulletin is to change brands of fuel to see if it goes away. It is caused by the sulpher content in the fuel. Mine is doing it right now as well, and I find it very aggravating to say the least.
Old Nov 26, 2003 | 06:37 AM
Default Re: Fuel Gauge Problem!!! (vettenuts)
[QUOTE]There are two bulletins out on this, and the last software update for the PCM for this problem was released last June. One of the recommendations in the bulletin is to change brands of fuel to see if it goes away. It is caused by the sulpher content in the fuel.[QUOTE]
:iagree: If these things don't work, you may have to get the fuel sending units replaced.
Old Nov 26, 2003 | 11:53 AM
carpe dm's Avatar
carpe dm
Try some Techron Fuel Injector Cleaner; add it to a tank of gas and go for a drive.... :yesnod: :)
Old Nov 27, 2003 | 12:27 PM
Vegas Vette
Default Re: Fuel Gauge Problem!!! (carpe dm)
Thanks guys! I will try the fuel system cleaner to see if it helps.. :cheers:
Old Nov 27, 2003 | 12:39 PM
LivinTheDream's Avatar
LivinTheDream
I was advised by a reputable dealer to be selective about fuels, but that's not always an option. I think GM blew it on this one with the tank design and components, though I understand why they did it after reading All Corvettes Are Red.
There are TSB's about this, and I had my sender replaced under warranty for the exact same thing. :iagree:
[Modified by LivinTheDream, 5:40 PM 11/27/2003]
Old Nov 27, 2003 | 06:30 PM
Playswithcars's Avatar
Playswithcars
Friend of mine with a 2000 vert had this problem. Turned out too be some loose wiring at the tank. Warranty fix. :D
To Fuel Gauge Problem!!!
