Rough Idle?
Old Nov 26, 2003 | 10:31 PM
low98vette's Avatar
low98vette
Default Rough Idle Please Help
I have a 98 vette and it has a rough idle. I took it to the shop and they said that it is running rich but the plugs show that it is running lean. Any help on this would be great. Thanks Guys Tate
[Modified by low98vette, 4:42 AM 11/27/2003]
Old Nov 26, 2003 | 10:51 PM
magnetized's Avatar
magnetized
St. Jude Donor '09
Default Re: Rough Idle? (low98vette)
:seeya Welcome
I've heard that a rough idle can be caused by the plugs, w/ the little platinum pucks falling off and widening the gap. I've got the same thing and will be replacing all 8 plugs shortly w/ NGKs to try and correct it :smash:
:crazy: Ride On ;)
Old Nov 26, 2003 | 11:15 PM
low98vette's Avatar
low98vette
Thanks magnetized. I will change the plugs this weekend. :cheers:
Old Nov 28, 2003 | 10:56 AM
carpe dm's Avatar
carpe dm
Default Re: Rough Idle Please Help (low98vette)
Welcome to the Forum. It could be many things including plugs, wires, carbon build-up, IAC valve, etc. I think there is an upgrade to your PCM program that will address this too; ask your dealer. :yesnod: :)
Old Nov 28, 2003 | 12:54 PM
low98vette's Avatar
low98vette
Thanks carpe dm. What is the iac valve. If I can change it out myself that would be great. :seeya
Old Nov 28, 2003 | 05:43 PM
Sleeknsilver98's Avatar
Sleeknsilver98
I had the same problem, it turned out to be a wire. If your going to do the plugs, replace the wires at the same time. It's cheap and it won't take you any longer. :cheers:
Old Nov 28, 2003 | 06:11 PM
RedC5's Avatar
RedC5
Default Re: Rough Idle Please Help (Sleeknsilver98)
My '98 has had a slightly rough idle since March '98 when new....I kind of like it as it feels like a race car.
Old Nov 28, 2003 | 08:29 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I had that problem for 3 years and it turned out to be a bad coil... :cry
VR :cheers:
Old Nov 28, 2003 | 09:05 PM
low98vette's Avatar
low98vette
How did you find out it was a coil? :confused: I replaced the plugs and wires today. It seemed to have eased the roughness a little, but it still idles at about 600 rpm. This is going to drive me crazy :banghead:
[Modified by low98vette, 8:08 PM 11/28/2003]
Old Nov 28, 2003 | 10:33 PM
texasredc8's Avatar
texasredc8
The idle is rougher when the A/C compressor is off.
Old Nov 28, 2003 | 11:25 PM
low98vette's Avatar
low98vette
If it is a coil how do you find out which one it is? :crazy:
Old Nov 28, 2003 | 11:31 PM
vetterdstr's Avatar
vetterdstr
Hookup a Timing light to the plug wire, then look for a steady beat of light... the one that does not have a steady beat is the bad coil... :yesnod:
VR :cheers:
Old Nov 28, 2003 | 11:47 PM
low98vette's Avatar
low98vette
Thanks for the help. :cheers:
Old Nov 29, 2003 | 05:13 PM
99 torch red vette's Avatar
99 torch red vette
I have a 99 vette, and it has a rough idle also. I am goin to try to clean the TB, then check the coils
I had already did a decarb. plugs, and new wires.
no luck
Old Nov 29, 2003 | 06:22 PM
LivinTheDream's Avatar
LivinTheDream
Have you checked out some of the other threads on this? It is entirely possible it's a characteristic of the cam. My 98 (bought it with 50K) has a slightly rough idle at times too. For grins, I swapped the original platinum plugs (looked great, no missing pucks) for a set of Delco Iridiums and added a set of MSD wires. No change. Prior to this, I had only swapped out the airbox (for a Blackwing), put on a friend's Granatelli MAF, and added a set of Borla's. Idle always the same after each mod, which I kinda expected.
I hooked it up to AutoTap yesterday, and there is nothing wrong--no codes, no misfires, nada. I don't mind the idle, but reading other threads got me curious if there was an ignition/other problem. Nope. Peace of mind, and $100 bucks for a nice upgrade I wanted to do anyway.
By all means check the suggestions out. If you have a friend with AutoTap or another analyzer, hook it up before spending $$ on things you may not need. Let us know how it goes!
Old Nov 29, 2003 | 07:32 PM
vetterdstr's Avatar
vetterdstr
Default Re: Rough Idle Please Help (LivinTheDream)
Funny thing I learned is that the coils can be bad enough to make the car run like garbage but not bad enough to throw a code... All along I was told by the dealership that if the coil was bad... it would throw a code. :rolleyes: Once I installed the new coil in place of the bad one... the car ran smooth as silk.
I spent 3 years with a high priced car that ran like garbage. :mad I took an engine building shop about 15 min to find my problem. Once you change your plugs and wires... Check the coils... it could be your entire problem.
VR :cheers:
Old Nov 29, 2003 | 09:24 PM
99 torch red vette
Default Re: Rough Idle Please Help (vetterdstr)
I cleaned the TB today and decarbed the motor, still rough idle for me also.
I hooked up a timing light to each wire but couldn't really see any difference. how did the shop determine yours, was it a really noticable difference?
To Rough Idle?
Old Nov 29, 2003 | 09:37 PM
vetterdstr's Avatar
vetterdstr
Default Re: Rough Idle Please Help (99 torch red vette)
When a coil is firing correctly the light will flash steady. If the coil is not working correctly it will flash steady then skip a beat... you will have to watch each one flash for 15 seconds or so to be sure they are firing correctly.
VR
Old Nov 30, 2003 | 09:23 AM
low98vette's Avatar
low98vette
The Chevy house said that there was 1280 missfifes in the history when they hooked it up to the computer. They said that everything was fine now. I am going to try the timing light fix today. Thanks for all the help guys. Tate :steering:
Old Nov 30, 2003 | 05:07 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
++++++++ The Chevy house said that there was 1280 missfifes in the history when they hooked it up to the computer. They said that everything was fine now. I am going to try the timing light fix today. Thanks for all the help guys. Tate ++++++++++++++++++++++++++++++++++++++
Let us know how you make out. 1280 misfires doesn't sound like a lot when you think about how many times the engine actually fires. I'm going to try the timing light thing myself.......as soon as I get mine back. I hate loaning things out and then when I need it.....I don't have it. Today would have been a perfect time to do this.
