Crank bolt removal :(
Old Nov 26, 2003 | 10:45 PM
dads01dream's Avatar
dads01dream
Default Crank bolt removal :(
Hey All,
How the HECK do I get the crank bolt off of an A4 Vette? Any suggestions? Also, is the torque spec for a new bolt REALLY 240lbs.??!!! And then after that you need to continue pulling on that darned thing another 140 degrees?
Please tell me I'm mistaken.
Lastly, I stopped by my local Chebby dealer today and picked up a new bolt for only $4.00 in change! Thought that was pretty reasonable, I believe I read elsewhere they were like twice that amount?
Take care all!
:cheers:
Old Nov 26, 2003 | 10:51 PM
blu00rdstr's Avatar
blu00rdstr
Default Re: Crank bolt removal :( (dads01dream)
Well, my experience with the Datsun days was to put a pipe over the socket wrench, put it against the frame, and tap the starter... :crazy:
With my A4 vette I removed the rubber plug under the flywheel bellhousing, put a crowbar in the flywheel hole, and slid a long pipe on the socket wrench.
Old Nov 26, 2003 | 10:58 PM
Gary2KC5's Avatar
Gary2KC5
Mike,
you might want to do some searches for an easy way to remove the bolt, it has been discussed before. I used a standard braker bar with a long metal pipe over the end to give me more leverage. You can also (being careful) wedge the breaker bar to a fixed study position and (with the coil packs unpuged) bump the starter. You must make sure everything has a good tight fit (socket securely on bolt) before giving it a bump.
I don't remember the exact spec's off the top of my head but it is like (with the old bolt) torque to 125, then remove bolt, put in new bolt, torque to 24 lbs. then strech it 140 degrees (or just more than a 1/3 of a 'round')
BTW: $4 bucks is a good deal.
If you need the exact specs, let me know I will look them up.
Old Nov 26, 2003 | 11:11 PM
dads01dream
Default Re: Crank bolt removal :( (Gary2KC5)
Great suggestions, guys! Anyone else have a few more ideas, just in case.
BTW, I too had a '71 240Z (man, that car was fun) but I never needed to remove the crank bolt. :nonod:
Old Nov 26, 2003 | 11:26 PM
blu00rdstr's Avatar
blu00rdstr
One more suggestion from the shade tree...
Use the socket wrench, long pipe, and whack it hard with a 2x4. :smash:
Old Nov 27, 2003 | 12:14 AM
jmX's Avatar
jmX
Hey All,
Take care all!
:cheers:
You'll need to wedge something against the flexplate gear, and you can do this by dropping the starter (2 bolts). There are holes in the flex plate that you can probably stuff a big allen wrench in, and then when you try to turn the motor over the allan wrench will catch and hold the motor tight for you.
Follow the instructions or torque specs on http://www.ls1howto.com and you'll be fine tightening the bolt, and no, its not 240lbft plus 140 degrees.
Jon
Old Nov 27, 2003 | 12:20 AM
dads01dream
Default Re: Crank bolt removal :( (jmX)
Hey jmX,
Here's a quote directly from LS1howto:
"Grab your biggest torque wrench and attempt to torque that bolt down to 240lbft. I have always stopped at 200lbft on my installs and I've never had a problem, so if you can't hit 240 (which I never have), don't worry about it. Now, break the bolt free and remove it.
Take your NEW crank pulley bolt and thread it in all the way by hand. Torque this bolt to 37lbft. Now, we need to stretch the bolt into place. Get your breaker bar and pipe extension, and try to turn the bolt 140degrees past where it is at now, keeping in mind the engine will be trying to turn some and those are degrees you can't count. Again, I always seem to get about 90-100 degrees worth (estimating, knowing what 90 degrees looks like) and leave it as is so don't worry about going crazy here."
Says 240lbs. & 140 degrees..... Am I missing something here? Please explain this to me further.
Thanks!
Old Nov 27, 2003 | 12:30 AM
jmX's Avatar
jmX
Read what you quoted again, there's 2 totally different bolts being used.
One bolt is 240lbft, the other is 37lbft+140 degrees
[Modified by jmX, 11:31 PM 11/26/2003]
Old Nov 27, 2003 | 12:41 AM
dads01dream
Ok, so the firswt bolt was the old one being used to push on the pulley? The new one only needs torque to 37#'s and then 140 degrees past that setting? Am I correct now?
:bb
Old Nov 27, 2003 | 12:52 AM
Av8ter's Avatar
Av8ter
that is correct. Use the old bolt to push the balancer back onto the crank, then remove it, install the new bolt, torque to 37 foot pounds and then turn an additional 140 degrees. I lost your email address, send it to me again and i will email you a copy directly from the service manual.
Old Nov 27, 2003 | 10:18 AM
Stephen02Z06's Avatar
Stephen02Z06
Default Re: Crank bolt removal :( (Av8ter)
To get the old crank pulley bolt loose use a high output impact and blast it off. The other ways listed above are way too much work.
Old Nov 27, 2003 | 11:40 AM
dave777's Avatar
dave777
St. Jude Contributor
Default Re: Crank bolt removal :( (Stephen02Z06)
:iagree: I also used an impact at 175 psi. Easy as it gets!!
Old Nov 27, 2003 | 12:21 PM
msuc5vette's Avatar
msuc5vette
During my cam install we followed the torque specs for the putting the balancer back on, and then the new bolt to follow.
2 weeks later my balancer had slid forward 1" and the bolt was touching the steering system.:cuss
I had to tear the steering out again, and put another new bolt on it :cry
This time I put some thread lock on and a friend and I pulled back on the breaker bar as hard as we coold while another friend held the brake to the floor.
Mine is a manual trans, but I would definately not mess with torquing it below spech. It is a miserable experience to have to do it twice. I have heard many people say now that the torque specs are too low.
To get the balancer back on I would also recommend getting a longer than stock bolt. We have done 4 cars now, and every one of them was a pain to get the balancer back on w/ the stock bolt. I think the truck motor may have a longer bolt. :thumbs:
Old Nov 27, 2003 | 12:57 PM
FKING1's Avatar
FKING1
Default Re: Crank bolt removal :( (msuc5vette)
:iagree: After my head/cam the balancer pulley slid forward after about a year, ruined the pulley and belts. New balancer was $160, bolt $9. Make sure you follow Maintenance Manual procedure quoted above using 2 bolts (old and new) with the 37 lb-ft and 140*.
Fred K.
Old Nov 27, 2003 | 02:20 PM
dads01dream
Default Re: Crank bolt removal :( (dave777)
When using the impact wrench, do I need to unplug the coil packs or something to avoid accidentally starting the motor??
:crazy:
Old Nov 27, 2003 | 02:40 PM
corvette184's Avatar
corvette184
:crazy:
only if the ign. key is only.....you wont have any problems....
Old Nov 28, 2003 | 08:16 AM
Wt99C5's Avatar
Wt99C5
Hey All,
:cheers:
Patches and I used a breaker bar and the handle off our floor jacks. Did the same deal on both our cars and it worked great.
To Crank bolt removal :(
Old Nov 28, 2003 | 08:20 PM
Stu in CA's Avatar
Stu in CA
Default Re: Crank bolt removal :( (Wt99C5)
Yeah, good tip, my floorjack handle fits over my Craftsman breaker bar too.
I used the "shade tree piston stop" to keep the motor from turning, stuffed a cotton rope in plug hole #2. You may need to back the pulley off a bit to free up rope if it doesn't pull right back out.
Was easier, faster, and safer than other methods, IMHO.
Old Nov 29, 2003 | 06:57 AM
pdd000's Avatar
pdd000
Default Re: Crank bolt removal :( (Stu in CA)
make sure u torque that bolt to 240ftibs. i had my pulley slide of 3 times!!!i finally got a 600ftib torque wrench and blasted it on to 250ftibs and it hasn't come loose yet :)
Old Nov 29, 2003 | 10:27 PM
dads01dream
Default Re: Crank bolt removal :( (pdd000)
Hey pdd....
I think you only need to torque the "old" bolt down that much if you've removed the crank pulley in order to set it back in place. In my case, I'm going to be removing the crank bolt only to "pin" the crank pulley for my ATI D1-SC install. The pulley is not being removed.
The problem is, once you remove the factory bolt a new one is required. The new bolt must be torqued to 37lbs. and then "Stretched" an additional 140 degrees. EEK!! Oh, and I'll make absolutely certain to use Loctite red thread sealer.
Have I missed anything here? :grouphug:
[Modified by dads01dream, 10:28 PM 11/29/2003]
