Mix runflat with non-runflat - Can it be done?
of course, I suppose this spring I can do some burnouts to "even the wear, honey honest! I can't just replace the fronts!" :lol:
Ed
Goodyear GS D3s/ Michelin Runflats A/S
Handling predictability: 8.18/ 7.48
Braking modulation: 8.29/ 7.45
Steering response: 8.11/ 7.50
Cornering stability: 8.07/ 7.65
In addition, the Goodyears are every bit as good as the all-season Michelins in the rain - quite amazing considering their superior dry handling characteristics.
My advice: If you want to play it safe and at the same time sacrifice ultimate handling, go with the Michelins. However, if you want the best and the .01% chance of needing to call a flatbed some day, go for the Goodyears. The choice is yours!
[Modified by Dave68, 8:26 PM 11/30/2003]
Also from tirerack.com's custoemr survey results ( < == better ):
GS-DS3 OEM Pilot Sport A/S ZP
HANDLING RATING 8.90 7.80 8.80
DRY TRACTION 9.2 7.8 9
WET TRACTION 9.1 6.4 8.9
SNOW TRACTION N/A N/A 7.5
RIDE COMFORT 8.7 5.6 8.4
NOISE COMFORT 8.6 4.6 8
WEAR 8.3 5 8
----------------------- end customer survey numbers
Warranty rating: 3* 4* 3.5*
(honestly, I don't get the 3/3.5 difference when looking at the warranty details)
TREADWEAR RATING 280/280 300/300 400/400
Interestingly enough, the OEM fronts sport a traction rating of A as opposed to AA like the rest in the comparison. The goodyears appear to be cheaper to purchase, and come with an optional (from tr) road hazard policy.
For those of us who like to run in the mountains, or drive through more of the year; where the risk of snow is higher, the AS-ZPs are a good choice. If you'll never encounter snow, or can afford to change tires for the seasons, by all means go with a tire aimed at summer usage.
Eventually I'll be getting a set of wheels and tires for track-only use (or drive to track , track, come home and swap). But for now, for me, a tire that may compromise a little in terms of ultimate traction in exchange for pretty good all-season, "extended mobility", and general street performance, the Pilot Sports A/S-ZP are a good choice.
After all, sicne we enve exceed the posted speed by much, and certainly don't street race, we don't push our cars to the limits on the street, right? Of course there are a few turns I'm confident I coudl take at 100 w/grippy meats. :smash:
Ed
http://www.tirerack.com/tires/Compar...peed_rating=YR
[Modified by Dave68, 8:38 PM 12/1/2003]
I picked up a nail in my left rear when I had the Goodyear runflats and in the right rear after I bougtht my Michelin ZPs. Lousy luck? Absolutely! I haven't had a flat on any of my other cars for years and years. Was I damn glad I had the runflats on the Vette? You bet! I wouldn't run non-runflats. I learn quickly.
Ed
At least with the runflat you can "shop around" when your tire goes, as opposed to mostly being stuck with either paying for a flatbed transport (likely not covered again), or going with what the tire shop you had to go to has or will get for you w/o bending you over.
Ed
:seeya
