Titanium welded to steel??
BUT....does anyone know if you can weld Ti to Stainless steel??
thanks
Welding of titanium by various processes is widely practised and service performance of welds is proven with an extensive and continuously extending record of achievements. Newer methods adaptable to titanium are further advancing the science, technology and economics of welding (for example at The Welding Institute).
Most titanium alloys can be fusion welded and all alloys can be joined by solid state processes. Unfortunately some engineers still believe titanium is difficult to weld, possibly due to its particular requirements for argon or helium gas shielding, or because in the past it has normally been handled only by specialist fabricators. Titanium is actually easier to weld than many metallurgically more complex metals and alloys.
Weldability of the commonly used ASTM Grades
ASTM Grades Weldability Comments
1,2,3,4,7,11,12,13,141
5,16,17,26,27 Excellent Commercially pure titanium and low alloy grades with minor additions of Pd, Ru, Mo etc.
9,18,28 Excellent Ti-3Al-2.5V alloy grades
5,23,24,29 Fair - Good Ti-6Al-4V alloy grades
Welding and joining methods appropriate to titanium include:
Arc Welding Processes, Tungsten Inert Gas (TIG), Metal Inert Gas (MIG), Plasma Arc (PAW).
Power Beam Processes, Laser and Electron Beam (EB)welding.
Resistance Welding, Spot, Seam and the Resista-CladTM cladding process.
Friction Welding, Rotary, Radial, Linear, Orbital, Stir, Stud and other specific jointing techniques.
Diffusion Bonding
Forge Welding
Explosive Bonding
Brazing
Soldering
Adhesive Bonding
What you need to do is first weld a 3rd type of metal that can be commonly welded to both steel and ti, then weld the two together, so as not to directly mix the steel and ti material in the welded joint.
You could try asking welding shops in your area about it, they would be able to answer this best.
And even if I'm wrong and you can weld them together...if my guess is right and your asking this for an exhaust project, keep in mind ti and steel (or SS) have substantially different thermal expension rates, and any such welded joint would likely not hold up to high temp cycles.
:cheers:
Check out the Nordam Group in Oak city, they are FAA approved repair facility specializing in repairing jet engine nacelles, (stainless/titanium) structures.
Diffusion Bonding
Forge Welding
Explosive Bonding
Brazing
Soldering
Adhesive Bonding
:confused:
yes, I want to weld some B&B speedway tips to an 02 up Z oh Ti exhaust :cool:
can it be done????
thanks
R
A
T
:confused:
Ti is very commonly TIG welded, MIG is also possible. But again, fusing it to steel or stainless steel is a whole 'nother ballgame.
:cheers:
:cheers:
:confused:
That quote above dealt with welding titanium (and it's alloys) only. It had nothing to do with welding Ti to SST.
:cheers:
thanks for the info :(
R
A
T
Sorry...
[Modified by J-Rod, 9:33 AM 12/9/2003]
[Modified by Blocktrdr, 11:30 AM 12/9/2003]
how would i secure them to the Ti pipes????
thanks for the great idea !!!
R
A
T
There is a loctite formula that is supposed to be permanent (think it is green) that should give a clean appearence. Slip fit would need to be very tight. If that doesn't work, there is always j.b. weld. Its designed to take a lot of heat.
I admire your tenacity with the project!
g
All this may sound complicated, but I bet it would be pretty cheap to do at a muffler shop.
[Modified by Blocktrdr, 7:09 PM 12/9/2003]
[Modified by Blocktrdr, 8:25 PM 12/9/2003]
GREAT idea.....there are 2 outlets on the Ti.....that would ensure proper alignment of the tips with no twisting...
R
A
T
