ERRATICGAS GUAGE NEEDLE
Old Dec 6, 2003 | 10:26 AM
JAMUSA's Avatar
JAMUSA
Default ERRATICGAS GUAGE NEEDLE
GAS GUAGE NEEDLE KEEP SHOWING EMPTY WHEN CAR IS FULL,ALSO GAS NEEDLE KEEP GOING UP N DOWN.
Old Dec 6, 2003 | 10:45 AM
RoliO's Avatar
RoliO
Default Re: ERRATICGAS GUAGE NEEDLE (JAMUSA)
Mine did the same thing this week. It steadily climbed up to the full tho after about 5 minutes. :confused: It doesn't go up and down tho. Just went up very slow! :smash:
Old Dec 6, 2003 | 10:59 AM
JAMUSA's Avatar
JAMUSA
Default Re: ERRATICGAS GUAGE NEEDLE (RoliO)
I WAS TOLD TO ADD A FUEL INJECTOR CLEANER CALLED TECHRON,THAT IS SOLD AT WALLMART......I HAVE ADDED TWO CANS WITH NO GOOD RESULTS.THE DEALER SAID THE FIX IS TO REFLASH MY COMPUTER,BUT I WOULD LOSE MY LSI EDITH,AND MY TUNER IS OUT OF TOWN.
Old Dec 6, 2003 | 02:06 PM
vettenuts's Avatar
vettenuts
Mine has done this recently also. Just a thought on my part. No problems all year, then suddenly these problems are all over the internet. The GM bulletin states that a different brand of fuel may resolve the problem. Since we have recently switched to "winter blend" of fuel, wondering if this is the source of the problem???
Old Dec 6, 2003 | 02:29 PM
MH2Lmaker's Avatar
MH2Lmaker
Default Re: ERRATICGAS GUAGE NEEDLE (vettenuts)
I just took my '98 into the dealer 2 weeks ago with basically the same problem. I would be driving along with a full tank of gas and the needle would drop to empty and warning would come on saying low fuel. They replaced the sending unit. So far so good. There is a bulletin on the sending unit (sorry, don't remember the number right now).
Old Dec 9, 2003 | 01:24 PM
TOPSPD's Avatar
TOPSPD
Mine did just as MH2Lmaker's did (see below). I tried different fuels, BG44k fuel inj cleaner with no success. I had my PCM reflashed recently by the dealer & it seems to be working fine although I haven't gone through many tanks with winter weather arriving around here.
TOPSPD :seeya
Old Dec 9, 2003 | 02:49 PM
vrus's Avatar
vrus
Default Re: ERRATICGAS GUAGE NEEDLE (TOPSPD)
My 2001 Coupe exhibited the same behaviour. After going back to the dealer to have the right-side fuel sending unit replaced the problem went away for quite a few weeks and then started happening again.
I read that fuel with high sulphur content causes these problems by fouling up the sensors.. I bought some fuel injector cleaner and used it with a fuel tank of gas and the problem went away...
Its been at least 4 weeks now and it hasnt happened once. Try the Techron that was suggested.. It might take 1 or 2 tank fulls with techron added before the problem goes away.
Old Dec 9, 2003 | 03:08 PM
AtHomeSoda's Avatar
AtHomeSoda
Well... mine used to fall to empty... then go back up... then it read over a 1/4 tank... started missing.. I got gas.. I put 19.187 gallons in a 19.1 gallon tank. The next tank said 1/$ tank... I got gas and put in 18.2 gallons... so it has gone nuts... wish someone out there makes an after market sensor to fix..
:rant: :U :banghead: :nonod: :sad: :confused: :mad :skep: :leaving:
Old Dec 9, 2003 | 03:12 PM
Goody's Avatar
Goody
Default Re: ERRATICGAS GUAGE NEEDLE (AtHomeSoda)
Some friends of mine have had this same issue with their Z as well. Required the new sensors in the tank. Been fine for the last couple of months.
To ERRATICGAS GUAGE NEEDLE
