156mph max?
Old Dec 7, 2003 | 06:40 PM
FLvette's Avatar
FLvette
Default 156mph max?
Owned my 02 for 1 1/2 years now and figured it was time to "open er up" I hit 156 on the HUD and it was in the red and the shift light was on. is this normal for an a4 coupe with no mods?
Old Dec 7, 2003 | 06:51 PM
NJ99FRC's Avatar
NJ99FRC
From: If you can see the car behind you, your not going fast enough
Default Re: 156mph max? (FLvette)
sounds like you need to shift into 5th :cheers:
Old Dec 7, 2003 | 06:53 PM
gojo's Avatar
gojo
That MPH would be consistant with being in 3rd gear.
FLvette's Avatar
FLvette
Default Re: 156mph max? (NJ99FRC)
I had it in OD
Old Dec 7, 2003 | 07:09 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
:confused: Seems a bit low however i would be more concerned with the tach in the red. I had the 2.73 factory rear. Only mod was airbox, 172mph and i'm sure there was more in the car. Something just is not adding up. Are you the original owner? Just curious if maybe someone changed the gears.
Bob
Old Dec 7, 2003 | 07:20 PM
FLvette's Avatar
FLvette
Default Re: 156mph max? (16Again)
Yes Ibought the car in june 02 it now has 11k on the odometer. Maybe i needed to let it shift into OD or lockup I may have got out of it just before it was going to shift...didn't want to spend the night in jail or bodybag :D
Bob [/QUOTE]
Old Dec 7, 2003 | 07:32 PM
BlueDragon's Avatar
BlueDragon
yes, that is way to low for a 2:73. You were either in third, or the previous owner changed the rear.
What is your RPM at 80 in fourth.
Jer
Old Dec 7, 2003 | 07:59 PM
Noran Raad's Avatar
Noran Raad
St. Jude Donor '08
:eek: Way too low... Stock(wise) you are supposed to be "faster" than a Z06. While cars are individually different, categorically you should be above 170mph, at least. Time to get her checked out.
Old Dec 8, 2003 | 12:07 AM
Malibu Vette's Avatar
Malibu Vette
Default Re: 156mph max? (Noran Raad)
I agree that is way too low. Im my 99 with 3.42 gears I saw 165 with lots left. Ran out of road.
Old Dec 8, 2003 | 12:45 AM
EuG's Avatar
EuG
I dunno I saw 180MPH and it was climbing FAST :eek: but I had to let off…. That’s a bit different setup though …. never mind ;) :jester
Old Dec 8, 2003 | 10:51 AM
V8_Club's Avatar
V8_Club
:iagree:
To 156mph max?
