lowering transmission
Old Dec 9, 2003 | 07:35 PM
pdd000's Avatar
pdd000
Default lowering transmission
is there a special attachment i can put on my floor jack to lower the transmition? or do i have to buy a special jack? im doing the job on jackstands.
Old Dec 9, 2003 | 08:25 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: lowering transmission (pdd000)
I have this big tranny adapter cradle that drops in place of the jackhead. It makes it much more stable. I've done it twice on mine. If you want to borrow it, let me know.
Old Dec 10, 2003 | 01:19 AM
pdd000's Avatar
pdd000
Default Re: lowering transmission (Fastguy)
wow. thanks for the offer fastguy, but i picked up chaep. is there any other special tools ill need :confused: im aslo putin a new clutch in while i replace the gears. the bearin tool comes with the clutch.
[Modified by pdd000, 6:31 AM 12/10/2003]
Old Dec 10, 2003 | 01:35 AM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Wow, brave man :D
Can you do some write up while in there:D?
Good luck with your project!
[Modified by mike76002, 12:35 AM 12/10/2003]
Old Dec 10, 2003 | 01:36 AM
pdd000's Avatar
pdd000
Default Re: lowering transmission (mike76002)
thanks :cheers:
Old Dec 10, 2003 | 01:12 PM
Fastguy's Avatar
Fastguy
The only "special" tools were the tranny adapter, a ratcheting car tie-down, and a pilot bearing puller. Do NOT hammer a dowel in the crank to pop the old one out, use a puller. The crank has an oil plug there and you will pop it inand therby totally screw yourself. I rented a puller at Autozone. It wouldn't adjust down small enough so I took the jaws off the end and actually threaded it into the bearing itself. If you do an archive search here for my posts, there are a few regarding driveway tranny swaps.
Old Dec 10, 2003 | 03:55 PM
pdd000's Avatar
pdd000
thanks again fastguy. i m starting the job right now .ill keep everyone updated. and of course, if i run into any problems, ill be back :)
[Modified by pdd000, 2:56 PM 12/10/2003]
Old Dec 10, 2003 | 06:13 PM
Monster231's Avatar
Monster231
just be a man and tka it on the chest. that what i used to do on the old jeep
Old Dec 10, 2003 | 06:36 PM
Fastguy's Avatar
Fastguy
Default Re: lowering transmission (Monster231)
:lol: The diff cradle, diff, halfshafts, torque tube and tranny probably weigh more than a Jeep.
Old Dec 10, 2003 | 07:41 PM
pdd000's Avatar
pdd000
:skep:
To lowering transmission
