My new dyno #'s (WOW)
Old Dec 13, 2003 | 04:43 PM
WiseGuyZ's Avatar
WiseGuyZ
Default Re: My new dyno #'s (niphilli2)
It is normal to get a LOT more torque than HP, but not that much! Great results. That camshaft must REALLY like N20.
I hear ya......but TNT told me that they see a 200ft lbs of tq increase on a stock ls1 engine. Im a heavily moded LS6......so thats why I see all that tq.....and of course CARTEK'S H/C design has something to do with it.
Old Dec 13, 2003 | 04:46 PM
WiseGuyZ's Avatar
WiseGuyZ
Default Re: My new dyno #'s (MC TORCH RED)
great numbers :iagree: which cam did you use. :cheers:
Its a cartek cam designed for nitrous. the specs are 224-228 .580 .590
Old Dec 13, 2003 | 05:31 PM
bruce1's Avatar
bruce1
Default Re: My new dyno #'s (WiseGuyZ)
Good luck at the track WwwwiseGuyZ.
You are flying!
Bruce1
:D
Old Dec 14, 2003 | 07:50 AM
WiseGuyZ's Avatar
WiseGuyZ
Default Re: My new dyno #'s (TEK WARRIOR)
:cheers: :thumbs: Stop f#$king around and put the 200 shot in it , after you upgrade your fuel system , of course.
I dont know TEK.......If I can hit low 10's on a 100 shot...... then what will a 150 shot give me???? 9's??????? maby I wont need a 200 shot after all.
But I want a 9sec pass on the stock bottom end no matter what it takes. Im also looking for trap speed's around the 135-140 mph range when its all said and done.
Hoprfully with the new throttle position switch that myself and a friend installed I should see a low 10 for sure on a 100 shot. The other way that I was activating the system was incosistant, as you already know.
Well, we will see on friday whats going to happen....Ive tested the system on the street and everything looks good.....but no traction on the street with the inital nitrous hit. Hopefully ACTO is prepped well so that I can hook up the car.
later
[Modified by WiseGuyZ, 7:51 AM 12/14/2003]
Old Dec 14, 2003 | 09:24 AM
niphilli2's Avatar
niphilli2
This is most of the reason you are seeing huge gains. N20 loves exhaust duration. Your heads must have excellent exhaust ports as well.
Old Dec 14, 2003 | 01:04 PM
WiseGuyZ's Avatar
WiseGuyZ
This is most of the reason you are seeing huge gains. N20 loves exhaust duration. Your heads must have excellent exhaust ports as well.[/QUOTE]
I would have to ask julio what was done to the heads.
Old Dec 14, 2003 | 09:04 PM
tomdcarguy's Avatar
tomdcarguy
From: A.M.R. Pound for Pound-Fastest Stock Bottom LS1 9.1x 10psi
:cheers: Great numbers Andy!! :cheers: Just don't miss a shift :steering:
Old Dec 17, 2003 | 06:29 PM
WiseGuyZ's Avatar
WiseGuyZ
Default Re: My new dyno #'s (tomdcarguy)
Ill be at CARTEK'S shop on friday 12-19...... Ill get dave to post the sheet.
Old Dec 17, 2003 | 09:08 PM
speedjohnson's Avatar
speedjohnson
It sounds like pure nuclear fission to me. :cheers:
Old Dec 17, 2003 | 09:18 PM
SpinMonster's Avatar
SpinMonster
Default Re: My new dyno #'s (speedjohnson)
Just curious, did you do the head and cam install yourself with their parts or did they do it?
Old Dec 18, 2003 | 12:07 AM
WiseGuyZ's Avatar
WiseGuyZ
Default Re: My new dyno #'s (SpinMonster)
No, they did it.
