Help: Friction modifier in M6 Trans
Old Dec 14, 2003 | 07:39 PM
bogielake's Avatar
bogielake
Default Help: Friction modifier in M6 Trans
During one of my midnight assembly projects I accidently put the friction modifier meant for the diff in the tranny (M6).
Do I need to worry? I hate to drain out 4 quarts of Amsoil if not needed.
If draining is required will I need to flush?
thanks for the help, :seeya
brad
bschmidt61@comcast.net
Old Dec 14, 2003 | 08:09 PM
see5's Avatar
see5
Default Re: Help: Friction modifier in M6 Trans (bogielake)
The syncros may need some friction and I am not sure how it will mix the fluid. See what the experts say.
Old Dec 14, 2003 | 09:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
$30-$40 bucks worth of fluid id NOT worth a $2500. Transmission! Just drain it out and put in some new fluid. You should be alright with a drain and fill! :thumbs:
Bill C
Old Dec 14, 2003 | 09:09 PM
kh24's Avatar
kh24
My tech actually has put that in my tranny before on purpose to try and help make the shifting smoother. I found no adverse effect to having it in the tranny and it did shift a little better even with GM fluid.
Old Dec 15, 2003 | 12:16 AM
bogielake's Avatar
bogielake
Default Re: Help: Friction modifier in M6 Trans (kh24)
Joe:
Thanks for the reply another buddy (former GM Powertrain Engineer) of mine that I emailed agrees with you,
"Brad, its not a problem at all..The modifier is actually closer in viscosity to the trans fluid and the "lubricity" changes of it would be next to nothing in the trans fluid".
4 oz in 4.1 quarts I don't think I'll worry about it.
The tranny was just put back together by Rodney, I'll probably put 500-1000 miles on it (once spring gets here in MI) and change it.
:auto:
To Help: Friction modifier in M6 Trans
