HP v TORQUE
Old Dec 16, 2003 | 06:28 PM
gojo's Avatar
gojo
Default HP v TORQUE
"The formula for hp is Torque X RPM divided by 5250. A dyno measures torque, and the hp is just a number calculated from the torque. So that is why they cross at 5250."
Lg
This is a quote from one of Lou's threads. Should go on a sticky so we can avoid another debate on how a Dyno measures HP. :yesnod: :lurk:
[Modified by jfpilla, 6:29 PM 12/16/2003]
Old Dec 16, 2003 | 06:40 PM
Monster231's Avatar
Monster231
Default Re: HP v TORQUE (jfpilla)
I would love to hear more about this
TTT for ya :iagree:
Old Dec 17, 2003 | 10:45 AM
davidfarmer's Avatar
davidfarmer
Default Re: HP v TORQUE (Monster231)
That is basic physics, and continues to be mis-understood. Some dyno shops really confuse people by having different "y" axis for torque and power, shifting the cross point on paper.
hp=torque*rpm/5250 on every engine
torque=hp*5250/rpm on every engine
Old Dec 17, 2003 | 10:55 AM
LG Motorsports's Avatar
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Who is that masked man??? :)
LG
Old Dec 17, 2003 | 11:28 AM
DickieC.99's Avatar
DickieC.99
Default Re: HP v TORQUE (LG Motorsports)
This may be a stupid question but i'm just curious, how do you measure hp and torque at the crank?
Old Dec 17, 2003 | 11:36 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
LG
:confused: :confused: :lol: :lol: :lolg: :lolg: :thumbs:
Old Dec 17, 2003 | 11:42 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
When I was doing a lot of dyno runs with my motorcycle the Dynojet dyno actually measured RWHP and it was only able to calculate Torque if you hooked an inductive pickup to a coil or plug wire. I am not sure if the car dynos work the same way.
This HP vs Torque article is good:
http://www.vettenet.org/torquehp.html
Old Dec 17, 2003 | 03:23 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Lg
I wonder if Lou quoted James Watt, the inventor horsepower. ;)
Old Dec 17, 2003 | 07:52 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: HP v TORQUE (DickieC.99)
On an engine dyno . Chassis dynos measure rwhp/tq. While we're on the subject - here is one of my favorites on TQvs HP http://mclements.net/mrc-PowerTorque.html#_ftn1. Easy, fun reading. :thumbs: FWIW>
joel
Old Dec 18, 2003 | 09:21 AM
davidfarmer
Default Re: HP v TORQUE (binksZ06)
A rear wheel dyno measure HP directly, by measure acceleration of a drum.
Accel x speed x weight (inertia) x constant = power
A Vericom etc works the same way, but uses linear acceleration of the vehicle instead of rotating acceleration of a drum
A flywheel dyno is different, it measure torque. They apply just enough load to stop the engine from accelerating, then measure it accross the rpm range. The load (torque) can then be converted into HP
Old Dec 18, 2003 | 09:37 AM
Duck916's Avatar
Duck916
Default Re: HP v TORQUE (davidfarmer)
There are at least a couple of different types of dynos in use. The popular Dynojet dyno calculates HP from the vehicle's ability to accelerate a drum of known weight. Dynojets can't apply a differing load to stop the aceleration and therefore you have to do a "pull" that runs through the engine's RPM range. An eddy current dyno acts more like the brake dyno described above. Note that manufacturers' HP ratings are expressed in BRAKE HP (BHP) because they are obtained using the brake dyno as described above.
The key point I think we need to take from the first post in this thread is that HP and TQ are interrelated. Neither one is more important than the other. People get confused by the fact most people quote the PEAK HP and TQ numbers, but that doesn't tell the whole story. There's that saying that people buy HP but drive TQ. What they really mean is that the peak HP figure obtained at 6000 RPM is not very important when most folks drive around at 2000 RPM. In that case, the power (HP) the engine produces at a given RPM is more important. Since it happens that TQ typically peaks much lower than HP (and the TQ curve tends to be flatter), the TQ figure is thought to be more important. However, I'd say what really counts is the TQ and HP produced at the RPM level you tend to drive at.
Whatever. Back to work.
[Modified by Duck916, 6:38 AM 12/18/2003]
To HP v TORQUE
