Startup procedure after oil change?
Old Dec 17, 2003 | 02:43 PM
redrodxp's Avatar
redrodxp
Default Startup procedure after oil change?
After I change my remote oil filter and drain the oil cooler, the engine runs for several seconds on startup with the low oil pressure warning on. This can't be real good for the bearings. Is there a fuse I can pull that will kill the ignition and fuel injection and let me spin the engine with the starter until the oil lines are full? I could pull the spark plugs, but there must be an easier way. :chevy
Old Dec 17, 2003 | 03:01 PM
VetteDrmr's Avatar
VetteDrmr
Default Re: Startup procedure after oil change? (redrodxp)
Maybe not the theoretically best way, but why drain the oil cooler? Admittedly it'll hold about a quart of old oil in the system, but I imagine you change your oil rather frequently, anyway.
HTH, and have a good one,
Mike
Old Dec 17, 2003 | 03:18 PM
StickTail's Avatar
StickTail
You could crank the engine over a few times shutting it off right away.
Old Dec 17, 2003 | 04:12 PM
redrodxp's Avatar
redrodxp
Hi - Thanks.... When I don't drain the cooler, I don't get that nice golden fresh Mobil1 5W-30 look. :chevy
Old Dec 17, 2003 | 04:14 PM
mbtc5vette's Avatar
mbtc5vette
Do you fill the new oil filter with oil before installing it? I do that and the warning light doesn't stay on any longer than usual. hth.
Old Dec 17, 2003 | 04:19 PM
Sandra Bigwoode's Avatar
Sandra Bigwoode
Default Re: Startup procedure after oil change? (mbtc5vette)
prime your oil filter as well with fresh oil before putting it on...
Old Dec 17, 2003 | 04:27 PM
Dave68's Avatar
Dave68
This happens to anyone after changing oil, especially with sideways-mounted oil filters. Don't worry about it.
Old Dec 17, 2003 | 05:07 PM
redrodxp's Avatar
redrodxp
Thanks to all - Filter is mounted horizontally, and I load it with oil until it runs down my arm. In the future, I will not watch the dic when I start up after an oil change. Just worrying too much about the best ride ever. :seeya
Old Dec 17, 2003 | 05:33 PM
carpe dm's Avatar
carpe dm
Fuel pump fuse; fuse that controls the injectors;etc. ? :lurk:
To Startup procedure after oil change?
