look at the difference ...
Old Dec 17, 2003 | 04:26 PM
pdd000's Avatar
pdd000
Default look at the difference ...
the new clutch is so light compare to the old one. unreal. also should i replace the pilot bearing? or is the old one ok. pat http://www.picturejudge.com/memberpi...s/IM000241.JPG
Old Dec 17, 2003 | 06:43 PM
corvette184's Avatar
corvette184
Default Re: look at the difference ... (pdd000)
a new bearing is about 15.00 from gm.......i wouldnt chance it :thumbs: :thumbs: i see you got that pesky line undone :hurray: :hurray:
Old Dec 17, 2003 | 06:47 PM
Patches's Avatar
Patches
Always replace the pilot bearing while you have access.
Old Dec 17, 2003 | 07:16 PM
mcd_57's Avatar
mcd_57
Default Re: look at the difference ... (Patches)
SPEC...good choice :thumbs:
Old Dec 17, 2003 | 08:47 PM
Monster231's Avatar
Monster231
Default Re: look at the difference ... (mcd_57)
[Modified by Monster231, 1:49 AM 12/18/2003]
Old Dec 17, 2003 | 09:02 PM
pdd000's Avatar
pdd000
Default Re: look at the difference ... (corvette184)
i cut the SOB :thumbs:
Old Dec 17, 2003 | 09:44 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
:thumbs: when in doubt cut that f'ucker. That clutch looks nice. Did you get the aluminum flywheel seperately, or does it come from SPEC as an assyembly? Do you have to get it balanced or does it just bolt up? One more thing, do you have a manual of some sorts that you're going by? How hard is all this? Just turning wrenches?
Old Dec 17, 2003 | 10:52 PM
pdd000's Avatar
pdd000
Default Re: look at the difference ... (Cobra4B)
yes the aluminum flywheel was extra. its supposed to be balanced from spec.i have a bunch of things im following for the install. i have a helms service manuel, im using cartecks write-up of the clutch install and on here askin tons of questions :) its definatly an involved job, but if i can do it any1 can :thumbs:
[Modified by pdd000, 9:54 PM 12/17/2003]
To look at the difference ...
