what do these codes mean?
Old Dec 19, 2003 | 12:10 PM
low98vette's Avatar
low98vette
Default what do these codes mean?
I went thru my codes today and these were in there.
Code one - 40BCM B2723H
Code two - BO RFA U1064H
Code three - A1 RDCM B221>H
A1 RDCM B221?H
Thanks Guys for any help. :seeya
Old Dec 19, 2003 | 12:24 PM
Patches's Avatar
Patches
Default Re: what do these codes mean? (low98vette)
B2723 PASS-Key Detection Circuit
U1064 Loss of Communications with BCM
A1 RDCM B221?H
The various Right Door Codes
B2203 Right Window Up Switch Fault
B2205 Right Window Down Switch Fault
B2237 Right Door Lock Switch Fault
B2239 Right Door Un-Lock Switch Fault
B2253 Key Cylinder Switch Fault
B2263 Horizontal Position Sensor Fit
B2265 Horizontal Position Sensor Fault
B2273 Right Mirror Motor Fault
B2275 Window Motor Fault
B2277 Door Lock Motor/Mirror Heater Fit
B2283 Battery #1 Fault
B2285 Battery #2 Fault
B2287 +5V Reference Fault
Old Dec 19, 2003 | 12:34 PM
low98vette's Avatar
low98vette
I am sorry, but i meant what is wrong that these codes were set. I know what they mean as far as description. Also I cant figure out these two codes at all.
A1 RDCM B221>H
B221?H
This is exactly how they appeared. The > and ? were in the code. I cant find them anywere on the codes sheet.
Thanks Guys. Sorry for the confusion. :seeya
Old Dec 19, 2003 | 02:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ttt
Old Dec 19, 2003 | 04:20 PM
low98vette's Avatar
low98vette
Anybody? :confused:
Old Dec 20, 2003 | 10:30 PM
Oldvetter's Avatar
Oldvetter
The H means history, they are NOT active problems.
[Modified by Oldvetter, 10:33 PM 12/20/2003]
Old Dec 20, 2003 | 11:23 PM
retiredsfsgm's Avatar
retiredsfsgm
Had the same thing happen to me. Four individual technicians at Four different Chevrolet dealers had no clue what they meant. Best bet is to go through and clear all your codes....key off, remove your negative cable from your battery for about 3 minutes and replace. Drive it a couple of days and check your codes again. Mine came back with the same codes, but they were complete without all the crazy stuff. Good Luck
:flag :flag
Old Dec 21, 2003 | 08:30 AM
Oldvetter's Avatar
Oldvetter
Default Re: what do these codes mean? (retiredsfsgm)
Check your battery for leaking. I never saw a > in any code !
To what do these codes mean?
