A/C Head control unit difference between 1997 and 1998 MY ?
I am looking for a used unit, and found a 1998, but not shure if this will fit !
Thanks for your help.
Jochen
Be warned that if you are replacing because the LCD has become dim, then the 97 may do it as well.
I replaced mine when it became dim with a similiar unit and it only lasted about 6 months and the replacement went dim. I would get a much newer model (2000+) for that problem.
thanks for your answer. Yes, i am talking about the dual a/c control unit. I have a 97 Corvette, and found an offer on ebay for a 98 unit.
So all units for the dual zone a/c from 1997 to 2004 are the same ?
So it might be the best to get a new one from GmPartsdirect.com ?!?
Jochen
