Left Turn Vibration
Old Dec 21, 2003 | 05:32 PM
IndyDog's Avatar
IndyDog
Default Left Turn Vibration
I hope you all can help with this one...my car vibrates (coming from the rear) at speeds over 40 while I'm making a gentle turn to the left. It's most noticeable driving on the highway when the highway curves to the left. The vibration is hard to describe, it's more like a humming noise that oscilates. If anybody has ever been on a plane and the two engines are slightly out of phase hum...hum...hum...hum...etc. that's the effect. Nothing when the car is straight or turning to the right. Bearing??? Diff??? Help
Old Dec 21, 2003 | 07:41 PM
Kenny94945's Avatar
Kenny94945
Default Re: Left Turn Vibration (IndyDog)
Well, ruling out that you feel the vibration at/ on the same road spot....
You'll have to jack the car up and shake the wheels and feel for a bearing.
Then look at all your a-arm bushings for damage.
Lastly, check for loose suspension bolts.
Wheels are torqued... yes?
Maybe a loose driver seat?
That 's the 02 I can offer.
Old Dec 22, 2003 | 11:32 AM
IndyDog's Avatar
IndyDog
Default Re: Left Turn Vibration (Kenny94945)
Thanks Kenny...
It's not the same spot in the road
Wheels are torqued properly
Not coming from the seat, it's a definate rear end issue.
I'll check the other items you mentioned.
Old Dec 22, 2003 | 01:48 PM
carpe dm's Avatar
carpe dm
Could be either. Check for bearing play, as suggested. Has your diff fluid been changed? :rolleyes:
Old Dec 22, 2003 | 03:20 PM
IndyDog's Avatar
IndyDog
Default Re: Left Turn Vibration (carpe dm)
Carpe...fluid level is good.
To Left Turn Vibration
