I was wondering if anyone has heard anything about dynatech's new exhaust for the C5's. Here's a link of what it looks like. http://www.rpmoutlet.com/c5hits.htm
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Re: dynatech supermaxx exhaust (John Shiels)
I have heard about it.
It is a poor copy of our LG Pro Long Tubes. It has a "Cast Steel Collector" which is not a Merge collector. It has cats that neck down to
2-1/2" then to into a stamped 2-1/2" x pipe. The cats flow 200 cfm less than the 3" on our headers.
And their production system has a 4 bolt flange connection that will cause ground clearance problems, and their clamps interfere with the tunnel.
>> Plus it is 28 Pounds heavier than the LG Pro Long Tube headers.<<
I would never take our LG Pro Long Tube headers and reduce our cats and X pipe to 2 1/2" or put a NON Merge collector on our system.
Imitation is a form of flatery or worse.
I will welcome a back to back with this copycat system.
