Which Hypertech should I go with?
Old Dec 23, 2003 | 06:48 PM
SLICKMAN's Avatar
SLICKMAN
Default Which Hypertech should I go with?
Which one should I use? The 160 deg or the 180 deg? I have the programer and I want to install a new therm also.
[Modified by SLICKMAN, 6:48 PM 12/23/2003]
Old Dec 23, 2003 | 07:05 PM
LS1LT1's Avatar
LS1LT1
Default Re: Which Hypertech should I go with? (SLICKMAN)
There's only one actual Hypertech (per model year car) unit but you must mean which thermostat setting or even which thermostat I assume?
You set the unit by which t-stat that you have in the car so if it's stock there should be a setting (no changes to that parameter maybe?) for it.
I would suggest going with the 160* t-stat (and obviously the subsequent Hypertech setting for it) depending on your climate and how often you drive in the real cold weather.
Old Dec 23, 2003 | 08:22 PM
SLICKMAN's Avatar
SLICKMAN
Default Re: Which Hypertech should I go with? (LT1LS1)
Yes, I'm looking to change the T-Stat.. I just did not know which one to go with.. I was leaning towards the 160 but I wanted everyone's input...
Old Dec 23, 2003 | 11:36 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It ALL depends on where you live and drive yoyr car!! If you live in Florida get a 160 deg stat! If you live in Ct and drive your car year around I would get a 180 deg stat!
You need to get your oil temp high enough to boil off any moisture that you accumulate in your in your oil.
BC :thumbs:
Old Dec 24, 2003 | 02:36 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Which Hypertech should I go with? (Bill Curlee)
BC :thumbs:
:iagree: :cheers:
Old Dec 24, 2003 | 03:10 AM
SLICKMAN's Avatar
SLICKMAN
Default Re: Which Hypertech should I go with? (LittleBoyBlu99)
I live in NY and I only drive the car in the non-winter months.. So, whats the thoughts, 160?
Old Dec 25, 2003 | 05:26 PM
saber's Avatar
saber
get the 160 - you can always turn the fans on higher if you like
Old Dec 28, 2003 | 09:24 AM
V8_Club's Avatar
V8_Club
BC :thumbs:
:yesnod: :yesnod: :yesnod:
To Which Hypertech should I go with?
