MAF Screen Removal
Old Jan 8, 2004 | 09:19 PM
  #61
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: MAF Screen Removal (ArKay99)
:withstupid: If your screen is having to block debirs then you've got big problems on your hands. :yesnod:
Old Jan 9, 2004 | 08:21 AM
  #62
C5BTW's Avatar
C5BTW
Default Re: MAF Screen Removal (Cobra4B)
As I mentioned in an earlier post, 1997-1998 LS1's had a fuel/air mixture that was on the rich side.
I have seen a number of articles over the years that reported individuals and tunners such as Doug Rippie achieved a 5 to 7 rear wheel horsepower gain on 1997- 1998 LS1's by removing the MAF screen, because this change leaned out the fuel/air mixture to a more optimum ratio.
In 1999, GM leaned out the LS1 fuel/air ratio, and in 2001 GM increased the LS1 MAF diameter from 74mm to 85 mm. As a consequence, removing the MAF screen on 1999 and newer LS1's offers little if any power gains.
Old Jan 9, 2004 | 10:50 AM
  #63
98VETTEC5's Avatar
98VETTEC5
Default Re: MAF Screen Removal (C5BTW)
Then how about designing a program to show how your idea works?? Then when your own program proves you wrong what are you gonna do? I know you think that because the engine is quote "sucking like crazy", air velocity will increase so much that even after the screen it won't decrease velocity and spread out.. ITS JUST A SCREEN!! IT WAS PUT THERE FOR EXTRA PROTECTION IN CASE SOMETHING GETS PAST THE AIR FILTER!! IF you have ever had an engine apart you would already know this. I have built to date four (4) custom turbocharged engines- not kits that i put together but totally fabricated. So I think that you should just stick to computers.
Old Jan 9, 2004 | 12:07 PM
  #64
i_york's Avatar
i_york
Default Re: MAF Screen Removal (98VETTEC5)
:bs
The MAF screen is an airflow straightener, not an air-filter failsafe device! Think about it, if you drove through a cloud of dust with no air filter, what protection do you think the MAF screen is gonna provide? None whatsoever! Before the days of fuel injection, did cars come with an extra filter in case you forgot to put the air filter in? Nope!
On the point of straightening the airflow, I believe it is still a good idea to retain the MAF screen. Airflow is turbulent by nature and the MAF screen helps even it out so each MAF wire 'sees' the same amount of air. Also, you'd probably be asking for trouble if you removed the screen and decided to install a Halltech Sidewinder (or similar) intake where the intake air has to turn a corner before it gets to the MAF.
Cheers,
Ian.
:cheers:
Old Jan 9, 2004 | 12:58 PM
  #65
99blackFRC's Avatar
99blackFRC
Now you had to get personal about it. But it's ok I know I'm right! :D
Actually, you are not.. And you are definitely missing the point that he's trying to make.. Not just once, but a few times from everything I've just read. You really need not be so cocky, he was dead on in every response to you.
Old Jan 9, 2004 | 01:04 PM
  #66
99blackFRC's Avatar
99blackFRC
Wrong again.. Are you just doing this to launch a flame war in this thread? Do a little research if you are in fact trying to have a serious discussion here. You're making yourself look very uneducated.
Old Jan 9, 2004 | 01:24 PM
  #67
98VETTEC5's Avatar
98VETTEC5
Default Re: MAF Screen Removal (99blackFRC)
All right go against GM. Like I said earlier what do I care
Old Jan 9, 2004 | 02:38 PM
  #68
57xray's Avatar
57xray
I repeat you should read this article. http://www.vetteguru.com/mods/howto/#effects :banghead:
Old Jan 9, 2004 | 02:51 PM
  #69
98VETTEC5's Avatar
98VETTEC5
Default Re: MAF Screen Removal (57xray)
I did, looks like we were both right on somethings and wrong on others. It says "First by removing the screen, you increase airflow. The PCM may need to be recalibrated to accommodate this new flow." MAY is the key word here. Maybe on 97-00 it's a good thing and on others it is not. But this thread is getting tired so farewell
Old Nov 22, 2010 | 09:47 PM
  #70
sfc rick's Avatar
sfc rick
Originally Posted by Cobra4B
Blah, blah, blah .
The screens are on the lsx motors (with the exception of the '02+ LS6) becuase of their use in the pickup trucks. The trucks don't have a straight intake path and need the screens to create laminar airflow (straighten it out) so the MAF car accurately read the airflow. The Corvette has a strainght intake path and has NO need for the screen. The problem is that you have to tune the car to run correctly. Since a screen-less MAF is flowing more air now the MAF calibrations will be off and the PCM is "seeing" less air than is actually flowing. Thus, the car can run lean. Now if you're getting a tune then rip that sucker out.
Bingo! You get it!
Will Handzel(Engineering GM Department head) wrote that using a screen in all vehicles early on was only to straighten air flow out since all vehicles used a crooked intake path(except Vettes) He states that you should remove it since all Vettes after 2002 didn't have them. That totally comes from the horses mouth and should end all controversy....maybe.
Old Nov 23, 2010 | 12:28 AM
  #71
soggysailor's Avatar
soggysailor
I remember Halltech actually recommends adding a screen when you install their CAI on 2002 to 2004 Z06. This was designed to eliminate the lean code issues and air turbulance when using their high flow CAI. Check out the Halltech web site for more info. The MAF screen is a keeper for me.
Old Nov 23, 2010 | 06:26 PM
  #72
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Quote:
Don't do it unless you plan on geting an LS1Edit tune to recalibrate the MAF tables. You will lose hp and torque because the air velocity passing the MAF wires is what is important, NOT volume. The PCM tables are built with the MAF screen installed and will return less agresive numbers for spark advance and A/F mixture without it.
Well, that's one point of view, On the other hand...When I frst got my Y2K, I modded it with ported MAF ends, (no screen), a Vortex, and a 160 thermostat, and it ran considerably better than stock, I gained 4 MPH at the strip. It ran just like stock at low throttle openings.
It is the correct point of view. The idle will be a bit rough removing the screen as well. The 1-2 hp gain is not really worth the headache with out a tune.
Old Nov 23, 2010 | 06:28 PM
  #73
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Originally Posted by sfc rick
Bingo! You get it!
The screen is to direct the air flow over the maf wire evenly. It has nothing to do with a crooked intake path.
