Synthetic fluids....WOW!!!
Old Dec 24, 2003 | 01:30 AM
BradSW's Avatar
BradSW
From: From San Diego to Bentonville, AR.....WTF was I thinking?!? Oh yeah, that free state thingy!
St. Jude Donor '15-'16
Default Synthetic fluids....WOW!!!
I just changed out the trans fluid in my MN6 with Redline D4 ATF and Redline in the differential also. All I can say is WOW!! You guys told me I would notice a difference in shifting and smoothness, but I never expected this big of a result from this change. I swear, the trans is even quieter.
Great mod / upgrade and VERY glad I did it. Highly recommend it to anyone wondering if it is really worth it.
[Modified by BradSW, 12:33 AM 12/24/2003]
Old Dec 24, 2003 | 05:30 AM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Default Re: Synthetic fluids....WOW!!! (BradSW)
I agree. I'm going with AMSOIL ATF and the 75W90 for the differential next month. I've heard great things about both synthetic fluids for our transmission and differential. Glad to hear you're happy with your results. Good luck! :cheers:
Old Dec 24, 2003 | 06:10 AM
:cool: When I change mine the next time, I will consider going this route also.
Old Dec 24, 2003 | 01:02 PM
carpe dm's Avatar
carpe dm
Happy here with Amsoil fluids. :smash: :)
Old Dec 24, 2003 | 01:16 PM
red1vette's Avatar
red1vette
Default Re: Synthetic fluids....WOW!!! (carpe dm)
I will be changing mine to amsoil in the spring, and I will be talking to IMQUIK then to get some! :thumbs:
Old Dec 24, 2003 | 01:47 PM
Jim 47's Avatar
Jim 47
Guys, your C5 came from the factory with Synthetic lubricant in the Differential. I agree that the Synthetic Redline MTF provides smoother and quieter operation of the trancmission.
Jim
Old Dec 24, 2003 | 01:53 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: Synthetic fluids....WOW!!! (Jim 47)
BRad, how many quarts of fluid did you need? I have seven quarts of D4 ATF in the garage, left over from when I changed the fluid in my old '93 automatic. I mean to drain and fill my '99's fluid in the spring...
Old Dec 24, 2003 | 02:08 PM
Monster231's Avatar
Monster231
Default Re: Synthetic fluids....WOW!!! (Matt Black)
Ive been reading about a number of different probs by doing that, anyone else having these probs
Old Dec 24, 2003 | 02:27 PM
FKING1's Avatar
FKING1
Default Re: Synthetic fluids....WOW!!! (Monster231)
00 Coupe. Redline in tranny, Diff and engine over 1-1/2 yrs. Great stuff & no probs.
Fred K
Old Dec 24, 2003 | 02:41 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
:lol: We're in the same boat. I just swapped my fluids and noticed a TREMENDOUS difference:
http://forums.corvetteforum.com/zerothread?id=716264
Old Dec 24, 2003 | 03:13 PM
C6~Missle's Avatar
C6~Missle
Jim
You don't use MTF in the M6. It takes Automatic D4 fluid. Makes a nice difference in the T56 especially in cold weather.
The original diff fill should be drained within 12K miles. All the wear occurs early in use. Best to get all the abrasives out of there in a reasonable time.
I used Redline without adding any modifiers. All is well.
mike
Old Dec 24, 2003 | 07:16 PM
BradSW's Avatar
BradSW
Mine took just under 4 quarts in the Trans.
Old Dec 24, 2003 | 10:03 PM
Jim 47's Avatar
Jim 47
Default Re: Synthetic fluids....WOW!!! (C5~Missle)
If you really want to get precise and technical C5~Missle, the C5 Manual Transmission takes DEXRON-III Automatic Transmission Fluid.
If you knew anything about lubricants you would know that the Redline MTL works great in the C5 transmissions, and has been designed to work in all synchro manual transmissions. The Red Line MTL has the identical viscosity charastics of the Red Line D4 ATF (they both meet SAE75W/80 viscosity requirements), they both have the same excellent low temperature fluidity, and also both meet the quality requirements of API GL-4 gear Oils. The real difference between the Red Line MTL and the D4 ATF is the MTL doesn't have the friction moderfiers in it to take care of the Automatic Transmission Clutches, which, of course, the Manual Transmission does not have. So, as far as lubrication the MTL, which has perfect frictional characteristics for the synchros, really is the BETTER lubricant for your Manual Transmission.
If you're really concerned about "all the abrasives" in your differential, why don't you drain and replace it immediately after picking up the car? Or, after only one month of driving? Wouldn't that get those auful abrasives out of there sooner? Where did all these abrasives come from?
As far as all the ware occuring early in use, it is true that the ring gear and the hypoid gear mate/mesh together to develop a very smooth ware patern on both the ring and pinion. This smoothing of the tooth sufaces is normal and allowed for with the proper clearences and bearing preloads established at assembly. This is NOT ware but a mating process that smooths the mating surfaces. Real ware occurs when the lubricant film srength between the ring and pinion gear is breached and you get metal to metal contact, or the operating conditions cause a bearing to fail. Under these conditions you get fine metal particals churned up in the lubricant and this causes further poor lubrication and destruction. Assuming a person doesn't beat the crap out of their Vette during the first 12 months of it's life, your statement that "all the ware occurs early in use" is inaccurate. Ware is an accumulative process, and in a differential is caused by poor or improper lubricants, high temperatures (which lower the film strength of lubes), low lube level, or severe/violent use by the driver.
I hope that this help to clear up previous inaccurate statements/opinions. :cool:
Jim Helm
Old Dec 24, 2003 | 10:52 PM
Gray Ghost GS
How many quarts does the Differential take?
Old Dec 24, 2003 | 11:04 PM
Jim 47's Avatar
Jim 47
Default Re: Synthetic fluids....WOW!!! (AlohaC5)
1.69 quarts plus 4 oz of limited slip additive.
Old Dec 24, 2003 | 11:25 PM
IMQUIK's Avatar
IMQUIK
Default Re: Synthetic fluids....WOW!!! (red1vette)
:iagree: This is a smart guy! :yesnod:
Old Dec 25, 2003 | 11:39 PM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: Synthetic fluids....WOW!!! (IMQUIK)
glad you are having success with it, i might have to try it. :thumbs:
Old Dec 27, 2003 | 02:20 AM
trogdor's Avatar
trogdor
Default Re: Synthetic fluids....WOW!!! (MC TORCH RED)
REDLINE OIL and diff fluids... big big differance... by the post i got it just in time... the 00 vert just turned 12k when i did this
Old Dec 27, 2003 | 08:54 AM
DI2FLY's Avatar
DI2FLY
:iagree: :cool:
To Synthetic fluids....WOW!!!
