*HELP* A/C temp control
If I turn on the heat in my C-5 1999 I get heat on the passengers side and cold air on the drivers side. I disconected the battery once and when i reconnected it I was able to get heat on both sides but then I had to relearn everything in the car (wheels key etc)Does this sound like the control head is bad. Should I replace it or is there and adjustment t hat I need. PS the A/C works fine on both sides all the time. :mad
