Oil leak *picture*
Old Dec 25, 2003 | 12:12 PM
GrandMasterFlash's Avatar
GrandMasterFlash
Default Oil leak *picture*
I have a small oil leak from the oil level sensor does anybody know what I need to do to stop this, is there a gasket that needs to be replaced?? Press re fresh on your web browser if you cant see the picture! Sorry I dont know the problem.
:sad:
[Modified by GrandMasterFlash, 6:13 PM 12/25/2003]
[Modified by GrandMasterFlash, 9:09 PM 12/25/2003]
[Modified by GrandMasterFlash, 9:10 PM 12/25/2003]
[Modified by GrandMasterFlash, 9:25 PM 12/25/2003]
Old Dec 25, 2003 | 12:25 PM
davidfarmer's Avatar
davidfarmer
Default Re: Oil leak *picture* (GrandMasterFlash)
Disconnect the electrical, unscrew it, and re-install with teflon tape. Tighten to 115 in-lb, according to the manual.
here is a link to the manual, if you want to take a look.
http://www.metricchemical.com/oil-lev.pdf
Old Dec 25, 2003 | 12:49 PM
GrandMasterFlash
Default Re: Oil leak *picture* (davidfarmer)
David
Your link does not work! :blueangel:
Old Dec 25, 2003 | 01:35 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
No picture came up but, first I would see if it was loose!!
Try to tighten it to the RECOMMENDED INCH POUND value. Make VERY sure that you use INCH pounds! If it continues to leak, remove it and use a thread sealer compound or teflon thread tape as previously recommended.
Bill C
Old Dec 25, 2003 | 02:18 PM
duosy's Avatar
duosy
Sure would like to see your picture as I may have the same problem. Please resubmit it so all can see. Thanks & have a great holiday season. :steering: :steering:
Old Dec 25, 2003 | 03:12 PM
GrandMasterFlash
Default Re: Oil leak *picture* (duosy)
Picture is back I had some minor problems, you need to push refresh if you can´t see the picture :cheers:
[Modified by GrandMasterFlash, 9:17 PM 12/25/2003]
Old Dec 25, 2003 | 03:22 PM
GrandMasterFlash
duosy: Do you have the same problem?
115in-lb! isn´t that much for that plastic thing?
Old Dec 25, 2003 | 03:45 PM
jmzvet's Avatar
jmzvet
INCH pounds NOT Foot pounds.
Old Dec 25, 2003 | 05:11 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Oil leak *picture* (jmzvet)
Try to RE- tighten the fitting first, It just might be loose! Thats the simplest thing!
KISS Keep It Simple Stupid :D
Bill
Old Dec 27, 2003 | 12:59 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
GrandMasterFlash
Did you ever have any success getting that oil leak to stop?!?
Please let us know.
Bill C
Old Dec 27, 2003 | 01:08 PM
carpe dm's Avatar
carpe dm
Default Re: Oil leak *picture* (Bill Curlee)
GrandMasterFlash
Please let us know.
Bill C
:iagree: :lurk:
Old Dec 27, 2003 | 02:25 PM
GrandMasterFlash
Default Re: Oil leak *picture* (carpe dm)
Not yet!:bb I will try fix it on Monday. I´ll let you guy´s know :cheers:
BTW Does anybody know what size socket to use, is it metric or inch?
[Modified by GrandMasterFlash, 8:31 PM 12/27/2003]
To Oil leak *picture*
