Engine whistle
Old Dec 25, 2003 | 04:55 PM
C5starman's Avatar
C5starman
CI 7-8 Veteran
Default Engine whistle
Got a high pitched whistle noise in the engine bay. Seems to be more on the left side. Not sure if it is an air sound or a metal sound. Rises and falls with the rpm. One of the pulleys maybe? Seems to go away or lessen after car has been driven a while. I checked the intake stuff - seems tight.
The only thing changed lately was new cat backs. Used the old exhaust gaskets.
Ideas?
Old Dec 25, 2003 | 05:32 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Engine whistle (C5starman)
This is a documented C5 problem. It is due to the intake manifold turblance. If your car is in warrenty the dealer may be able to fix it!
BC
Old Dec 26, 2003 | 11:52 AM
Arkay's Avatar
Arkay
Default Re: Engine whistle (Bill Curlee)
BC
Mine is out of the 3yr/36mo warranty. What is the problem and how can it be corrected?
Dick
Old Dec 26, 2003 | 01:39 PM
myblackC5's Avatar
myblackC5
i have a 98, and it does the same thing? no warranty! :eek:
Old Dec 26, 2003 | 08:33 PM
mowrey96's Avatar
mowrey96
99 w/ the same noise. I would like to know the fix.
Old Dec 26, 2003 | 09:15 PM
oufan2929's Avatar
oufan2929
Default Re: Engine whistle (mowrey96)
yea, i dont know if mine is the same noise, but it makes it between about 1300-1500 rpms. i'm also having different belt noises as well. i'm about to go crazy on both. the 1300-1500rpm noise is not nearly as bad however. sounds like some sort of exhaust leak
Old Dec 27, 2003 | 02:31 AM
bac68's Avatar
bac68
My '98 Vert has it too! :banghead:
Old Dec 27, 2003 | 10:46 AM
bowtiebandit's Avatar
bowtiebandit
BC
Whistle Noise From Intake Manifold/Throttle Body (Replace Intake Manifold) #02-06-01-021 - (05/22/2002)
2001 Chevrolet Corvette
with 5.7L Engine (VINs G, S -- RPOs LS1, LS6)
Condition
Some owners may comment on a whistle noise coming from either the intake manifold or the throttle body. The noise is most noticeable between 1100 and 2000 RPM.
Cause
This condition may be the result of airflow through the intake manifold.
Correction
Replace the intake manifold with the part listed below.
Parts Information
Part Number
Description
Qty
88894339
Manifold, Intake
1
Old Dec 27, 2003 | 02:41 PM
myblackC5's Avatar
myblackC5
well it's time for the next mod....manifold time. are they hard to change?
Old Dec 27, 2003 | 07:40 PM
C5starman's Avatar
C5starman
CI 7-8 Veteran
Default Re: Engine whistle (myblackC5)
Thank you for the response. I would have posted again sooner, but I went out of town.
Old Dec 28, 2003 | 02:29 PM
Ellinaras's Avatar
Ellinaras
Everything posted above was really helpfull but, the same noise started coming out of my car after I ported my T.B and installed it back on...
So could it be the result of the porting? Why should I change the manifold if the porting caused it? :confused: (other than annoying sound)
Old Dec 28, 2003 | 04:38 PM
Z.06's Avatar
Z.06
Default Re: Engine whistle (bowtiebandit)
I had this problem on my '01 Z06. The dealer replaced the manifold. I still had a slight whistle. After two more trips to Mr Goodwrench, he determined that my water pump was making the noise. He replaced the waterpump and the noise was reduced but not eliminated. Another year later, and I now have a loud whistle from my engine when cold. The car has only 12k on it. What next?
:banghead:
To Engine whistle
