Ticking noise from engine...
Old Dec 25, 2003 | 05:47 PM
1crazyfatboy's Avatar
1crazyfatboy
Default Ticking noise from engine...
On cold mornings I have this ticking noise, sounds like valves; it disappears once warmed up. Any suggestions. :confused:
Old Dec 25, 2003 | 08:03 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: Ticking noise from engine... (1crazyfatboy)
It's probably piston slap, take it to the dealer because you can probably get an extended warranty for free.
BTW, I love the username :lol: :lol: and welcome to the forum :seeya
[Modified by runamuk, 7:04 PM 12/25/2003]
Old Dec 25, 2003 | 09:54 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
:iagree: 2001 was a problem year for piston rings, I thought it was only for the Z06, but I know someone else who had an oil consumption problem with his 2001 coupe, and they replaced his rings. It could be a hydraulic lifter that bleeds down over night, and the noise goes away when it pumps back up.
Old Dec 26, 2003 | 12:17 AM
Tom T.'s Avatar
Tom T.
Default Re: Ticking noise from engine... (vette#one)
And, it may only be the injectors cycling. Some noise is okay. Have a good mechanic check it out.
TT
Old Dec 26, 2003 | 12:19 AM
Tom T.'s Avatar
Tom T.
Default Re: Ticking noise from engine... (Tom T.)
:_dupe: Sorry, I forgot you said it goes away. However, a little extra ticking for a few seconds on start up isn't necessarily terrible--just go ahead and have someone look at it. Best of luck.
TT
Old Dec 26, 2003 | 02:30 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Ticking noise from engine... (runamuk)
:iagree: :yesnod: :yesnod: :thumbs:
Old Dec 26, 2003 | 02:32 AM
LittleBoyBlu99
Welcome to the forum (1crazyfatboy). :cheers: :party:
Old Dec 26, 2003 | 08:35 AM
vettenuts's Avatar
vettenuts
Default Re: Ticking noise from engine... (LittleBoyBlu99)
There are a couple of theories floating around at the moment. I had a GM tech tell me it was carbon related and use GM part # 12345515 to clear it up over two tanks of gas (one bottle per tank). This did help so it might be worth a try.
Terry Dyson is looking at the oil pump and has a theory that the oil pump may be cavitating when cold. Also, the high copper content in the used oil analyses may be the result of the oil pump as well.
I have the same problem.
To Ticking noise from engine...
