I just bought a set of ceramic pads but, I am at a loss as to one thing.
Can some one tell me what the two black spacer things are and where they go?? I am sure they attach to the back of two of the pads but do they go on the inside or outside pad? TIA
Could you post the results of your mod ie.
Less dust Squeel etc.
I am tired of cleaning the dust from the wheels and looking at doing the same mod you are.
:flag
I am hoping to get them on next weekend over the holiday along with Baer rotors and upgrade to the '04 shocks. It should be fun weekend.
I will let you know what I think of them after the install. With the OE pads I can really mess up a clean wheel after two hard stops.
Let me clarify.
Looking at the front set of pads. There are 4 pads total. 2 inside pads and 2 outside pads. The kit only contains 2 of the black shims NOT 4.
Yes I realize you don't want to put the shim on the wear area of the pad. :lol:
But, do the 2 shims go on the backside of the Outside pads or on the backside of the Inside pads. The kit does not have 4 shims. Only two.
They go on the outside pad,( the one that you see through the rim). I installed them on mine and no problem's yet. little to no brake dust. :thumbs:
