Those rusty rotors
Old Dec 29, 2003 | 03:03 PM
C501's Avatar
C501
Default Those rusty rotors
My beautiful '01 was a daily driver for someone before I bought it and it has very ugly looking rusty rotors.
I was thinking about pulling them off and painting them or getting them powder coated. Does anyone know of a shop in Fort Worth that will powder coat?
When painting rotors & calipers, what kind of paint do you use - high temp enamel or just the 99 cent cans?
Also, what color should the rotors & calipers be on a non-Z06, plain Jane C5?
TIA!
Old Dec 29, 2003 | 05:24 PM
Arthur6's Avatar
Arthur6
Default Re: Those rusty rotors (C501)
I bought Drilled and Slotted Rotors from GMPartsDirect.com.
Loved them, but they rusted almost instantly. So, I bought a pint of
Rust-O-lium Gloss Black and a pack of small foam "brushes". I left the rotor on the car, burshed on the black paint. Unless you look REAL close you cannot see the brush marks, the rotors look GREAT.
The stock rotors are painted with something, so mine didn't rust.
ART
Old Dec 29, 2003 | 09:44 PM
kirbyloid's Avatar
kirbyloid
I clearcoated my rotors and they look great, painted calipers to match car Magnetic red and they look great matching car.
Old Dec 29, 2003 | 09:52 PM
joeflyer's Avatar
joeflyer
Default Re: Those rusty rotors (Arthur6)
I used the brush-on Rustoleum, too. It's not necessary to remove all the rust, just most of it.
Old Dec 29, 2003 | 10:00 PM
Vet72man's Avatar
Vet72man
Before I installed my erradispeeds I painted them with black barbeque grill paint and they look very nice. :thumbs:
Old Dec 29, 2003 | 10:16 PM
BAD 99's Avatar
BAD 99
ART
i did mine but on the hub i cleaned and sprayed with HI TEP CLEAR i love it
Old Dec 29, 2003 | 10:23 PM
USARMYTTT's Avatar
USARMYTTT
Default Re: Those rusty rotors (BAD 99)
Are yall talking about painting the whole rotor or just the hats?
Old Dec 29, 2003 | 10:52 PM
HAYABUSA1's Avatar
HAYABUSA1
Default Re: Those rusty rotors (USARMYTTT)
I PAINTED THE CENTER AND THE VERY OUTER OF THE ROTOR WITH BLACK HIGH TEMP PAINT, (EVERYTHING YOU CAN SEE THAT THE PAD DOESN'T TOUCH) STILL ON AFTER 5K.
Old Dec 29, 2003 | 11:11 PM
Vet72man's Avatar
Vet72man
Paint the whole thing, the pads will knock off what doesn't need painted. :yesnod:
Old Dec 29, 2003 | 11:55 PM
MTWallet's Avatar
MTWallet
Default Re: Those rusty rotors (Vet72man)
Uhh, if you do this you will have a HUGE mess on your hands. DO NOT paint the entire rotor and expect the pads to clean the surface for you. You will gum up the pads and ruin them.
Removing the calipers only takes a few minutes and then you can paint the hats and vent portion of the rotors. If you get paint on the surface of the rotor, just use a razor blade to scrape it off after it dries. I removed my rotors, bead blasted them, primed and painted with high temp semi-gloss black and they still look brand new.
Old Dec 30, 2003 | 12:29 PM
99Z51R's Avatar
99Z51R
Cruise-In III Veteran
St. Jude Contributor '04
I took mine off and then painted the whole thing with "cast blast". kinda gives the original look. Then I scraped the contact area off with a razor, turned out OK.
Eric
Old Dec 30, 2003 | 04:48 PM
MTWallet's Avatar
MTWallet
Default Re: Those rusty rotors (99Z51R)
99Z51R, those look great! That cast blast is great stuff. I have also used alumablast for aluminum parts and they look brand new.
Old Jan 1, 2004 | 08:25 PM
DelMonteZO6's Avatar
DelMonteZO6
Default Re: Those rusty rotors (MTWallet)
:iagree:
This man did it right! You should definetely remove them from the car and glass bead them, prime and paint with high temp. They will look great!!
[Modified by DelMonteZO6, 1:28 AM 1/2/2004]
Old Jan 2, 2004 | 09:12 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: Those rusty rotors (DelMonteZO6)
If you get them hot the paint will burn off if not a good Hi temp paint. POR15.com
Old Jan 2, 2004 | 01:39 PM
For my calipers, I used Folia Tec paint - hard as nails and looks great - dries to where you do not see any brush marks. Did mine in red.
To Those rusty rotors
