CHANGING WHEELS SENSOR QUESTION
Old Dec 29, 2003 | 03:34 PM
99SSC5's Avatar
99SSC5
Default CHANGING WHEELS SENSOR QUESTION
99 VERT WITH BENT RIMS PASSENGER SIDE. FOUND OUT GETTING NEW GY GSD 3 THAT THEY WERE MESSED UP. REPLACEMENTS FROM HOUSE OF WHEELS HOUSTON, THANKS BOB. WILL I HAVE TO REPLACE O RINGS ON SENSORS WHEN CHANGING TO NEW WHEELS? IF SO, WHAT AND MAYBE A PART NUMBER. THANKS FOR YOUR HELP. EXPERIENCED PLEASE CHIME IN. :confused:
Old Dec 29, 2003 | 05:13 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: CHANGING WHEELS SENSOR QUESTION (99SSC5)
Not quite sure about the question but here are some part numbers:
1997 - 2000 10438853 sensor 10268438 seal 10268439 nut
If you are changing wheels you should change seals.
Old Dec 29, 2003 | 09:15 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
If that is our forum vendor House of Wheels, Bob is in Florida. If we are talking about the same guy, I think he will give you the O-rings if you ask him. I don't want to make that commitment on his behalf, but he has done this in the past.
Old Dec 30, 2003 | 09:55 AM
99SSC5's Avatar
99SSC5
THANKS FOR THE HELP. I NEED SEALS. :hurray:
Old Dec 30, 2003 | 10:38 AM
Cruises's Avatar
Cruises
You should also remove the Caps Lock. :yesnod: :yesnod: :D
To CHANGING WHEELS SENSOR QUESTION
