O2 code help??? P0133 and P0153
P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P1153 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
I called Lou at LG and he recommended I connect the rear O2 sensors to the front wiring and install them in the front bungs, and I did (I had to buy from LG an adapter to mate the rear O2s to the front wiring). I put O2 sims in the rear sensor wiring. The codes (the ones you mentioned above) went away but were replaced with these:
P0133 Heated Oxygen Sensor (HO25) Slow Response Bank 1 Sensor 1-B
P0153 Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1-A
I called Lou and explained the above and was advised to replace the O2 sensors (remember I am using the rear O2s in the front bungs with the front wiring). Car ran ok for about three days and then the second set of codes came back...
I guess I am going to have to get LS1 Edit and turn those codes off...
:confused: :confused: :confused:
:D :D :D
I still have error code problems...
