another gear ?
Old Dec 30, 2003 | 02:32 PM
sjk103098's Avatar
sjk103098
Default another gear ?
Is it true you lose top end speed when changing gears, if so how much, is that a good thing or a bad thing ... :thumbs:
[Modified by sjk103098, 2:05 PM 12/30/2003]
Old Dec 30, 2003 | 09:33 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Default Re: another gear ? (sjk103098)
Well, considering that this car is geared for 170+ MPH, and I don't know any responsible adult that would go that fast on any public road, I really don't see the point. Makes perfect sense to me to give up 10 or 15 MPH on the top end for acceleration that you can actually use / enjoy. Just my .025 cents.
:smash:
Old Dec 31, 2003 | 10:26 AM
ROJO99's Avatar
ROJO99
Default Re: another gear ? (Dan_the_C5_Man)
:iagree:
Old Dec 31, 2003 | 10:45 AM
Patches's Avatar
Patches
Top speed on the stock setup is achieved in 5th gear. With a lower rear gear, you will lose top end on a stock setup. Keep in mind that the C5 is drag- and hp-limited where top speed is concerned. With some more motivation under the hood, theoretical top speeds could be approched.
As an example, with 3.42's, theoretical top speeds in 5th and 6th gears are 194 and 288 mph, respectively. With 4.10 gears they are 162 and 240 mph, respectively.
Old Dec 31, 2003 | 10:50 AM
chaase's Avatar
chaase
St. Jude Donor '12
Default Re: another gear ? (Patches)
:iagree:
You may end up with a higher top speed in the end if extra gear allows the engine to overcome to drag limit that it currently has.
Chris
To another gear ?
