50th Anniversary - suspension leaks?
Old Dec 30, 2003 | 08:11 PM
rynd2it's Avatar
rynd2it
Cruising
Default 50th Anniversary - suspension leaks?
Just had oil change done at 12,000 and mechanic said ALL FOUR shocks are weeping. Car has the magnetic suspension system.
Is this a known problem? unusual? any reports?? I'd like to know before taking back to the dealer for a warranty claim
[Modified by rynd2it, 5:12 PM 12/30/2003]
Old Dec 30, 2003 | 09:07 PM
carlmorrell's Avatar
carlmorrell
Default Re: 50th Anniversary - suspension leaks? (rynd2it)
I had my 50AE (1 year old) up on a lift last week and noticed the same thing. Took it to dealer yesterday. He agreed (duuh), and now I am waiting for new shocks. Should get them on next Monday.
I noticed the fronts had more leakage than the rear.
Also noticed spewage on differential. Dealer claims the factory overfills it. But will check when the shocks are getting replaced. I handed him a TSB on leaking drive shaft seal. It appears to me the side covers have leaked at the gasket. I believe there is a TSB on that.
Carl
Anyone want to bet that when they change the shocks, they won't even look at the differential?
Old Dec 30, 2003 | 10:31 PM
danielschulzjr's Avatar
danielschulzjr
Default Re: 50th Anniversary - suspension leaks? (carlmorrell)
As far as the differential over fill I think theres some truth to the overfill condition. I thought mine was leaking and after I changed the fluid no more leaks. I dont know what they think they gain in overfilling them, I guess its better than too little fluid.
Old Dec 30, 2003 | 10:39 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: 50th Anniversary - suspension leaks? (danielschulzjr)
:cool: :cool: :cool: :flag
Old Dec 30, 2003 | 10:41 PM
LittleBoyBlu99
Welcome to the forum (rynd2it). :cheers: :seeya :seeya
Old Dec 31, 2003 | 08:56 AM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
Dang. No, I haven't heard about that. I have F55 in my vette as well. After 16 months and 8k miles, I don't think that I have that problem, but I'll take a look over the weekend.
Old Dec 31, 2003 | 10:54 AM
chaase's Avatar
chaase
St. Jude Donor '12
Default Re: 50th Anniversary - suspension leaks? (GTC)
I'll have them look at the next oil change, but nothing yet (8m and 3500miles)
Old Dec 31, 2003 | 12:00 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I think I remember reading of one member of www.50thregistry.com having this problem but thats it, so far overall I think this has been a very good system and as for overfilling the diff at the factory, I believe that one also, I've heard that from several people. :cheers:
Old Dec 31, 2003 | 03:40 PM
Bob50th's Avatar
Bob50th
Thanks for the info .
I will have to take a look when it warms up a bit. only 4,000 miles so far.
Old Dec 31, 2003 | 04:25 PM
CR555's Avatar
CR555
... and mechanic said ALL FOUR shocks are weeping. Car has the magnetic suspension system.
I noticed the same thing with my wife's F55 vert...
Old Dec 31, 2003 | 08:35 PM
rynd2it's Avatar
rynd2it
Cruising
No bets :)
I stopped going to the dealer as I got fed up with them screwing up my tire pressures and leaving greasy finger marks all over it. Last time, after I told them to leave the tires alone as they were set correctly at 30 psi, they let them down to 20 psi because they said they were at 45 psi. You would really think a dealer would be able to use a tire gauge and might possibly have noticed the warning message on the dash :rolleyes:
Ah well, back we go and get the shocks changed
Thanks everyone who responded
Old Dec 31, 2003 | 08:54 PM
bowtiebandit's Avatar
bowtiebandit
Haven't seen any leaking yet at my shop as of yet. DId have to replace some shocks for throwing codes though.
To 50th Anniversary - suspension leaks?
