Differential Break In ????
Old Jan 1, 2004 | 01:47 PM
99SilverC5Coupe's Avatar
99SilverC5Coupe
Default Differential Break In ????
Thinking of having rear gears done... How do you break-in the new differential? If I drive to a shop will a cruise back of several hundred miles be a plus or minus? :confused:
Old Jan 1, 2004 | 01:54 PM
carpe dm's Avatar
carpe dm
Default Re: Differential Break In ???? (99SilverC5Coupe)
The answer is yes, you should "wear-in" your gears carefully. The drive home will be a plus for you, if you take back roads (slower speeds and curves) and vary you speed as much as possible. Enjoy! :)
Old Jan 1, 2004 | 02:19 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Differential Break In ???? (carpe dm)
everything I've read says 500 miles... and a few figure eights; for proper break in.
To Differential Break In ????
