Dexcool
Old Jan 3, 2004 | 02:31 AM
skidmarc's Avatar
skidmarc
Default Dexcool
Guys whats the deal between orange vs pink dexcool??? I have seen both and dont know the diferences....can someone elaborate?
Old Jan 3, 2004 | 08:01 AM
vettenuts's Avatar
vettenuts
Default Re: Dexcool (skidmarc)
To my knowledge, there are not two versions. Initially red, the coolant does take on an orange-ish color as it ages. Made by Texaco for GM, you can get it cheapest at Wal Mart. The Prestone stuff is not the same, and last I knew, did not meet GM specifications.
Old Jan 3, 2004 | 10:17 AM
Golf Man's Avatar
Golf Man
Humm................I bought prestone a couple of months ago.
GM Dex-Cool Approved was printed on the container.
Anyone else got any info supporting a difference between
Prestone and Texaco?
:seeya
Old Jan 3, 2004 | 10:39 AM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Re: Dexcool (vettenuts)
:iagree:
________________________________________ ________________________
I changed mine after 76,000 miles.
Old Jan 3, 2004 | 11:01 AM
Pumba's Avatar
Pumba
Marc,
I would like to suggest that you and other forum members take a look at Evans NPG+ coolant - www.evanscooling.com . I was informed about it by Ron Davis Racing Radiators and Darton Sleeves. Both RDR and Darton strongly recommend against DEXCOOL. They cite problems with it's useful life, and what it does to aluminum parts if left in a cooling system too long.
Evans coolant is a LIFETIME coolant. You do not mix it with water. I installed it in my Z06 cooling system when I installed my Ron Davis Racing radiator.
Old Jan 3, 2004 | 12:31 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
They have been having problems with Dexcool... I am not using it on my new LS6 blower motor... :nono:
VR :cheers:
Old Jan 3, 2004 | 01:26 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: Dexcool (Pumba)
Thanks for the info. :cheers:
Old Jan 3, 2004 | 02:49 PM
c5chris's Avatar
c5chris
Default Re: Dexcool (vetterdstr)
VR :cheers:
I stopped using Dexcool altogether. Im using distilled water and Redline Water Wetter only. This was after a few people I talked to had problems with their Dexcool turning into sludge. These are car people who regularly check their cars and not people who ride their cars to the ground.
Old Jan 3, 2004 | 03:06 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Dexcool (c5chris)
VR :cheers:
what kind of mileage are they at when they see sludging?
thanks
Old Jan 3, 2004 | 03:52 PM
vettenuts's Avatar
vettenuts
Default Re: Dexcool (kewlbrz)
Sludging is caused by low coolant, period. There have been several papers presented on this at the automotive trade seminars, two of which I have previously posted in an effort to stop mis-information. A three year study has bore this out. One problem you can run into with Dexcool is not using a 50/50 mix, the corrosion protection is reduced and can be ineffective at lower levels.
I have changed all my cars to Dexcool including my 89 Suburban and 89 Bonneville. Inspections of the block and radiator using a boroscope show they are completely clean and I have no problems.
As for problems with aluminum, the ph of Dexcool is designed for aluminum.
Old Jan 3, 2004 | 06:49 PM
skidmarc's Avatar
skidmarc
The Dexcool I bought was orange when I opened the new container... :confused: :confused:
Old Jan 3, 2004 | 09:20 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Good info here thanks. Something to think about for the spring. :thumbs: :seeya
To Dexcool
