problems with coil
Old Jan 3, 2004 | 05:02 PM
rollinred's Avatar
rollinred
Default problems with coil
any member out there have had a problem with a coil going bad or gone bad? i had one replaced about a month ago, and today cranked the car up and having the same problem when the coil went bad. :mad is there a high performance coil that i can buy?
[Modified by rollinred, 10:04 PM 1/3/2004]
Old Jan 3, 2004 | 05:47 PM
racetchr's Avatar
racetchr
Default Re: problems with coil (rollinred)
How did you determine it was a coil rather than something else? Just curious.
:confused:
Old Jan 3, 2004 | 06:23 PM
rollinred's Avatar
rollinred
Default Re: problems with coil (racetchr)
i took the car to frank parra and they put the car on their computer and it detected the bad coil,they replaced it and it solved the problem,until this morning :mad
Old Jan 3, 2004 | 06:54 PM
carpe dm's Avatar
carpe dm
Sounds like another trip for you; hope they can determine what has caused the problem. Please come back and let us know what happens. :)
Old Jan 3, 2004 | 07:05 PM
Bone_Stock's Avatar
Bone_Stock
Default Re: problems with coil (carpe dm)
I had the same problem. One of the coils went bad and then another a month later. I don't think there is an aftermarket coil but GM did revise the coils, probably for this reason. The new coil that you had installed should be a different part # and the epoxy coating is probably black instead of white. I am speaking from experience of a 97 model. I don't know what year you have and I'm not exactly sure when GM changed these coils. My G/F has a 2001 LS1 and it has the new coils on it, so somewhere in between. One other thing; check your fuses before you make another trip back to the shop. People have mistaken misfire codes with the coil packs when it was only a fuse to start with. I hope this helps.
Let me know what you come up with.
Old Jan 3, 2004 | 07:58 PM
rollinred's Avatar
rollinred
Default Re: problems with coil (Bone_Stock)
hey bone stock you are exactly right about the difference in the coil the one i had on there at first was white, and the new one they put on was black, my car also is a 97 with a lot of mods,i will be at the shop early monday morning will let you know the results :thumbs:
Old Jan 8, 2004 | 11:09 PM
rollinred's Avatar
rollinred
got red back from the shop today the tech said that it was a injector struck wide open causing the car to flood out, thanks for all those whose responded :thumbs:
To problems with coil
